Old 10-31-2006, 05:40 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
Old gas tank for speaker mount
Has anybody tried this? Someone mentioned it and it got me thinking, wow that could really work (i think) or someone should come up with a speaker box shaped like the old gas tank and oila a home based ready to order. Think about all the old gas tanks people are just willing to get rid of and then later you have to send your old one in to get a price cut on the new one all fabbed up with speakers of your choice. could work.
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 10-31-2006, 07:25 PM   #2
Gray Ghost
Gray Ghost's Avatar
Re: Old gas tank for speaker mount
Only problem I see is that you'd be firing into the back of your seats unless you had buckets.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 10-31-2006, 07:26 PM   #3
wibilly
wibilly's Avatar
not much of a sound guru but i think it would rattel like the tin can it is. not to mention take up more space that could be better used in my opinion
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-31-2006, 07:29 PM   #4
Boise69
The Hammer Man
Boise69's Avatar
lol yea but i dont really mean the can itself, but re-fabbed with sound insulation and mod in a way it wouldn't sound like a gas can. but i thought by posting that question someone would come forward with exactly that and it was actually done. When i take mine out i would trace the lines of the tank and make something to fit just like the tank.
1997 MBZ E420
Old 10-31-2006, 07:41 PM   #5
roj2323
the only way it would work properly as a sound box is if it was rigid. there is also the anount of volume behind the speakers to contend with. in short the tank as is, is too flexable and far too large volume wise to get a good sounding system. you are much much better off making a box with the vloume you need out of MDF. it will work better and you will have room for extra stuff like the amp.
roj2323 is offline   Reply With Quote
Old 10-31-2006, 08:43 PM   #6
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
If you could find a way to fiberglass the inside of it... It would definately take out the flimsiness. Also, those gas tanks really AREN'T that big. Depending on the subs you get, it would probably be just enough volume after the sub displacement and fiberglass, especially if you stuck a few aero ports in it. My 12s call for 1.9 ft^3 each... Wouldn't even be enough room to fit them ported.
Pl4yboy is offline   Reply With Quote
Old 10-31-2006, 09:07 PM   #7
greasemonkey
greasemonkey's Avatar
That's kind of what I did, needed a little bass in the rig and added 2 fairly shallow 10s in an MDF box covered in suede. I even used the gas tank mounting holes with longer bolts. Nice back massage after a long day.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 10-31-2006, 10:14 PM   #8
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
You can also fit 12's back there, and they fire into the back of the buckets, but she still sounds great. Here's mine, made a box the exact width of the cab (never will take it out, if I could) out of 3/4 MDF, covered with carpet, and bolted a panel on top to steady the box and help thwart theft.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 01-30-2013, 10:15 AM   #9
Tshort1
Tshort1's Avatar
I know this thread is Way old but am wondering if anyone has come up with any other ideas over the past few years. I am thinking about cutting an old tank in half lining the inside with sound deadener and bolting it back together.
Tshort1 is offline   Reply With Quote
Old 01-30-2013, 11:26 AM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Have you checked the "Truck Audio" forum? I would think there would be a lot of threads on this over there... Scroll down to the bottom of this page and you will see the "Forum Jump" box. Click on the little arrow on the right side of the box and a list of all the different Forums will come up. Scroll down to the "Truck Audio" forum and click on it.
LockDoc
Leon
Old 01-30-2013, 11:29 AM   #11
AirSpeed
AirSpeed's Avatar
It would sound horrible, subs produce an incredible amount of pressure, even with sound deadener the tank would flex and vibrate like crazy. It would be much better and far easier to build a cabinet out of MDF. If you build a sealed alignment you could make it much smaller and have room for other stuff.
AirSpeed is offline   Reply With Quote
Old 01-30-2013, 11:31 AM   #12
Tshort1
Tshort1's Avatar
Thanks for the Info.
Old 01-30-2013, 12:32 PM   #13
68gmsee
Active Member
68gmsee's Avatar
Many years ago I did some research about this subject. Even got a book about building speakers. They recommended a solid enclosure -preferably made out of 1/2"to 3/4" wood. Particle board was what they recommneded. Now MDF is a common material used for DIY.
If the fuel tank with the thin metal were used, the vibrations by the speakers would eventually loosen or crack any mounting a person could rig up. Probably would sound tinny as mentioned above. I guess a person could bolt a heavy board in front of it for stability but it probably would be easier to remove the tank an build a proper enclosure.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-30-2013, 01:56 PM   #14
sprint_9
sprint_9's Avatar
If you build a box to fit your specific location be sure to build it with the proper internal volume for the sub or speaker you are installing into it. This can make a huge difference in the overall outcome. I would also go with a sealed box, in a small cab like our trucks have I cant imagine you would need a ported box. Ported boxes are bigger and harder to get tuned properly, especially if you are limited in the dimensions that you have for your box.
This is a decent site for box calculating, as well as other car audio related topics. http://www.carstereo.com/help/articles.cfm?catid=1
sprint_9 is offline   Reply With Quote
Old 02-14-2013, 04:43 PM   #15
Tshort1
Tshort1's Avatar
Well I decided to try it out. I split the tank in half and cut out the peice I was going to use. I sanded it down and painted it, and then lined the inside with peal and seal. I then made 3/4 inch MDF sides, and a front. Before I attached them I used 3/4 inch weather strip and applied to all mounting spots. Then I screwed it all together. I used some duroglass filler to fill a few blemishes on the ends. I carpeted the whole thing. I will let you know how it sounds when I get ready to do the final install on it. If it sounds like crap I will start over and use all MDF. I'm hoping it works though and it fits in the cab perfectly using 3 upper, and two lower gas tank mounts.
Old 02-14-2013, 04:46 PM   #16
Tshort1
Tshort1's Avatar
I will be useing all polk audio speakers. 4 DB 6.5, 2 in the console and 2 in back coners where I made the MDF speaker holders. The sub will be 8" polk DB series also.
Old 02-14-2013, 04:50 PM   #17
Scott>72-GMC
Scott>72-GMC's Avatar
I like my gas tank one reason I like these trucks that good old gas cap on the cab
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
