Old 02-14-2013, 05:31 PM   #1
BrutonLS1
BrutonLS1's Avatar
Cannot get header to seal!!!
Howdy guys,
I've been through 2 gaskets on the passenger side!! right from the start up they putt and leak out the bottom. The second time I did my absolute best to center it and tighten the bolts evenly from inside/out ( I hate that heater core by the way!!!)
any ideas?
-Bruton
1968 GMC long bed 5.7/700R4
--I'd rather push a Chevy, than drive a Ford.--
BrutonLS1 is offline   Reply With Quote
Old 02-14-2013, 05:35 PM   #2
69GWC
Re: Cannot get header to seal!!!
Have you tried those copper header gaskets.
Is you exhaust binding up and not allowing the header to set on the head correctly
69GWC is offline   Reply With Quote
Old 02-14-2013, 05:37 PM   #3
Sammy
Throw away the gaskets. Get a tube of the black RTV. cleans both well no oil. Put the rtv about an 1/8 " bead all around be liberal. Let it set for 3 or 4 minutes each side and bolt it up. Some even put it on the bolts but doubt it is necessary unless they get loose on you. Also recommend you retorgue them after a short drive or in a week or so. Tryed the gasket thing and this works. Haven't seen it fail yet. Good luck
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-14-2013, 06:04 PM   #4
1967chevytruck
we use ultra cooper when it sets up you cant pry it off
1967chevytruck is offline   Reply With Quote
Old 02-14-2013, 10:27 PM   #5
bonnieclyde100
take a straight edge ands see if the header is flat you might have to resurface the header to make flat. i had one that would not seal and i put on belt sander to make flat.
bonnieclyde100 is offline   Reply With Quote
Old 02-14-2013, 10:36 PM   #6
firedog
firedog's Avatar
We also let it set over night prior to driving it anywhere. Make sure it is the hi temp black rtv. Was told this trick by some dirt track racers.
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 02-14-2013, 11:21 PM   #7
sapper4
Iave always had good luck with paper gaskets. Soak them in water overnight and install them wet. As soon as you getthem torqued, take the truck for a drive and get it up to operating temperature. The heat will dry the gaskets quickly and help them seal.
sapper4 is offline   Reply With Quote
Old 02-16-2013, 06:59 AM   #8
kelbystanley
use 2 gaskets
kelbystanley is offline   Reply With Quote
Old 02-16-2013, 07:14 AM   #9
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
You tell that heater core who's boss brother....
Seriously though...is the header unbolted from the collector? it can put a little bit of a twist on the header making it not seat properly, not much! but thats all it takes. Just a thought.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 02-16-2013, 07:29 AM   #10
Scott>72-GMC
Scott>72-GMC's Avatar
Set of these bolts might help to so they don't back out
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 02-16-2013, 10:01 AM   #11
1972crewcab
1972crewcab's Avatar
Remflex gaskets. They work great no trick to putting them on and comes right apart when you need it to.
1972 gmc k2500 ochra & white (best colors ever)i like them
1971 gmc crew cab (in progress)
1985 toyota ext pickup trail rig (cat yellow)
2009 rzr
1972crewcab is offline   Reply With Quote
Old 02-16-2013, 10:22 AM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I use copper gaskets top and bottom and not leaks..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
