Can anyone ID this power steering box?
![]() ![]() Bought from junkyard. Was told mid 80s. Any details you can give me will be helpful. I'm gonna try to put it on my 69 2wd. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Re: Can anyone ID this power steering box?
Its a 4wd box, not sure if you can use that on 2wd.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
How to tell difference?
The difference is in the pitman arm, location of the pitman arm and the attachment of the pitman arm. The 2wd pitman arm fits on a splined shaft and is held on by a large nut. The 2wd pitman arm points to the rear when the box is centered. On the 4wd the pitman arm is clamped to the splined shaft and points outward to the left with the box centered.
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks y'all. I called the junkyard and suppose to swap out for a 2wd. I now see the difference.
