Quick Question Regarding Brake lines
Hey guys!
I have searched and searched but am a little confused. I'm getting ready to stick a 6.2 with 6l80e tranny in my '72 burb. It was originally a big block truck so the lines are 1/2" and 3/8" return if I'm not mistaken. I see everyone is running new lines from the fuel tank/ pressure regulator/ pump etc. Is this really necessary? Will the factory hard lines not work? Can't I just change out the rubber hoses with fuel injection hoses and clamps? Am I missing something? My truck has a factory in line fuel filter setup which is where I was planning on putting the Corvette Fuel Pressure regulator. Will the factory hard lines not withstand the pressure of the fuel pump? THanks for the advice guys!! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
meowMEOWmeowMEOW
Re: Quick Question Regarding Brake lines
Well the corvette regulator would eliminate the return hard line from the engine bay....so re-using that line won't happen.
You could probably keep the 3/8 line as a feed; the truth is though, by the time you set everything up, it might just be easier to run a new line. Brakeline is cheap, and the insurance of knowing its new on 58+psi of fuel pressure is nice insurance. Its like $12 worth of line. Also, I have seen aluminum line used on carb fuel applications, and it will blow apart under FI pressure loads.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I am using the stock lines on mine, there is NO reason not to if they're in good condition. I have done this on every LSx conversion I have done and have yet to have a problem.
They are more than up to the task. |
Thanks for the info guys! I think I will try them out before I replace them.
