Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-14-2013, 09:44 PM   #226
Corts60
Just here to tinker
Corts60's Avatar
Re: '60 GMC Suburban (Project D-Daddy)
I was able to pull the 'burb out today and sweep up. The weather is finally nice enough. Here are some current photos. Also, I picked up a 351 V-6 the other weekend and started a tear down on it. I'll be installing it probably next winter. This winter I just need to get the windows all back in and the floors finished.
And here is the the 351 when I got it:
Old 02-14-2013, 09:51 PM   #227
Corts60
Just here to tinker
Corts60's Avatar
Here is the 351 currently. Everything is all torn down and, unfortunately, I foudn a spun rod bearing on #3 which means the short block is going off to the machine shop. I was hoping to just throw some new bearings and rings in it and go, but that is not to be. The crank had standard bearings in it though so it should be no problem turning it.
For those of you that don't know, the 351 has a bore of 4.56. Big mothers!
All the components are cleaned up and ready for paint:
And since I am going to be running TBI on this engine when it goes back in, and nobody in the world makes adapter plates for the Stromberg WWC pattern, I had to design my own adapter plate. I am going to have a buddy machine this up out of 1/2" aluminum for me.
Old 02-14-2013, 09:51 PM   #228
c.brown
c.brown's Avatar
Nice work looking good
1966 suburban slammed fuel injected 6.2L
My build
c.brown is offline   Reply With Quote
Old 02-15-2013, 10:34 AM   #229
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Kool
johnnyclack is offline   Reply With Quote
Old 02-15-2013, 12:00 PM   #230
88Lt1wagon
Awesome stuff, I've never gotten to look at a GMC V6 up close, that is wild
-Jason
'66 C10 LWB 2 BBL 283 w/ T-5
'90 V1500 Suburban TBI 350 w/ 700R4
88Lt1wagon is offline   Reply With Quote
Old 02-16-2013, 04:21 PM   #231
Corts60
Just here to tinker
Corts60's Avatar
Here's the progress for today. I had to grind all of the surface rust inside the window frames and prime/paint. I got the drivers side done today and hopefully I'll be able to do the pass. side tomorrow and then all of the window frame prep will be completed. I just ordered the windshield gasket, so hopefully I can get that installed in the next couple of weeks.
Old 02-16-2013, 07:48 PM   #232
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Nice work!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 02-16-2013, 08:50 PM   #233
Nice!
Old 02-16-2013, 09:12 PM   #234
88Lt1wagon
You'll find it at Fred Meyer
-Jason
Old 02-17-2013, 05:51 AM   #235
Desert.Chevy
Desert.Chevy's Avatar
Cool build
Desert.Chevy is offline   Reply With Quote
Old 02-28-2013, 09:22 PM   #236
Corts60
Just here to tinker
Corts60's Avatar
Progress! So, this week I got my Precision Brand windshield gasket and I installed it onto my windshield last night. I used 3M weather strip adhesive and taped all the hard bends and left it over night. I did the work inside so everything would be at room temperature.
Today I came home and installed the stainless steel trim. I am excited to put this thing in! I'll be that much closer to driving her again. It has been a long 5 months.
Old 02-28-2013, 09:32 PM   #237
Old 03-02-2013, 01:26 PM   #238
justcuz
justcuz's Avatar
Cort,
What kind of paint are you using for the interior. Is it special mix spray cans or have been lucky enough to find closely matching colors for the Sub. It is nice that you are doing the interior close to stock, many of these old dashes get hacked up so badly it is tough to fix them. Looking good buddy!
justcuz is offline   Reply With Quote
Old 03-03-2013, 01:31 PM   #239
Corts60
Just here to tinker
Corts60's Avatar
The interior color I've been getting at Lowe's. It is Rustoleum Stainless Steel. It's a little darker than stock, but I actually like it better and the finish is perfect I think.
Old 03-03-2013, 01:34 PM   #240
Corts60
Just here to tinker
Corts60's Avatar
Woohoo! Got the windshield in yesterday. And get this: with my girlfriends help, it took us all of 35 minutes!! After all the threads I read where guys have snapped windshields and glass companies have screwed them up, it was super easy, I thought. I am going to write a separate thread on what I did and how it was so easy for me.
PICS:
Old 03-03-2013, 01:50 PM   #241
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Well i can tell you from expierence that on a 64-66 with the stainless trim I have seen glass guy's try to insert the windshield into the trim slot in the rubber more then once....The old school guys get it. But some of the newer glass guy's get confused with all the slots in the rubber....Infact I once watched a glass guy try to reverse the rubber and put the outside in the inside...Good job for doing all the research and setting yourself up for a easy install....thats awesome....glad it all worked out for you
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 03-03-2013, 04:40 PM   #242
justcuz
justcuz's Avatar
That 351 with a TBI will be a torque monster for sure. A perfect candidate for some 2.73 or 3.00 gears. The 4 spd will almost be a requirement now to handle the torque of that engine.
Old 03-03-2013, 10:57 PM   #243
Corts60
Just here to tinker
Corts60's Avatar
Yeah man, I'm really excited about dropping that 351 in next winter!
Here is a victory pic of the windshield install:
Old 03-17-2013, 09:59 PM   #244
Corts60
Just here to tinker
Corts60's Avatar
Finally got the passenger side quarter window frame prepped and painted. Also squeezed in some time to prime the floor area that is being kept. I will be replacing the toe boards and rockers this next winter.
Old 03-17-2013, 10:04 PM   #245
Corts60
Just here to tinker
Corts60's Avatar
It's costing me a lot of money to get the quarter windows back in so unfortunately all the other little things I want to accomplish are getting pushed back.
The gasket set for one side of windows is $209! I got a quote yesterday to have new windows cut for the sides and it looks like they are going to be around $70 a piece. That's $280 a side for windows and $209 a side for gaskets = $489 per side. Damn. I didn't want to spend that much on just windows, but I guess I haven't really got a choice. I could re-use about 6 of 8 original windows but they are foggy and de-laminating and it would suck to spend that much on gaskets and put the old windows back in.
Old 03-18-2013, 08:32 AM   #246
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I don't know this guys prices, but he has a very good rep on the hamb,
you might check with him...
http://www.jalopyjournal.com/forum/s...d.php?t=614524
Old 03-21-2013, 01:05 AM   #247
SlackScotty
This is looking fantastic. What a great ride
SlackScotty is offline   Reply With Quote
Old 03-21-2013, 08:58 AM   #248
MikeS.
MikeS.'s Avatar
Cort, looks like you have a fine ride there and are taking the time to do it right.
Where did you buy your side window gaskets from? I need to replace mine, fortunately for me the glass is in good shape. Except for the driver side door, it's cracked.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 03-21-2013, 09:15 AM   #249
Corts60
Just here to tinker
Corts60's Avatar
I got the quarter window seals from Steele rubber.
Old 03-21-2013, 10:38 PM   #250
Corts60
Just here to tinker
Corts60's Avatar
Exciting things today!
Well, starting yesterday anyways. I was on my home from work and swung by this fabric supply shop just for kicks to see what was going on in there. Digging through their bolts of vinyl, I found a sweet vintage pattern that looked like it belonged in our trucks as the headliner. Unfortunately it was a pale pink color. Haha.
So, I bought 3 yards of it anyways and today I started installing it with an 1/8" foam backer for padding into my suburban. I spray painted it the same color that the rest of the interior is and all I can say is... well, look at the pics and you tell me what you think!
Looks freaking awesome to me! And factory!
