Old 02-14-2013, 09:59 PM   #1
bryan76
alternator ?????
i have a newer alternator thats good but its not the 12 and 6 clock mounting positions what other alternators can i use with the 12 and 6 clock positions work that is more than the stock 63 amp
bryan76 is offline   Reply With Quote
Old 02-14-2013, 10:06 PM   #2
rfmaster
rfmaster's Avatar
Re: alternator ?????
Any 10SI or 12SI alternator can be re-clocked into a desired position. Simply back out the four long bolts that hold the back half to the front half, but DO NOT separate the halfs. Twist until two wire plug is in desired position - i.e. 9, 12, 3 or 6 o'clock position.
http://www.madelectrical.com/electri...elcoremy.shtml
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-15-2013, 02:32 PM   #3
bryan76
the one i have is newer than 10 or 12 thinks its cs style it was a serpentine set up alternator
Old 02-15-2013, 03:23 PM   #4
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
I have one of the never ones too. I had to pull the bolts out and rotate it to the correct position. It also came with a serpentine belt pulley that I had to change out for a v-belt pulley.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
