Old 02-14-2013, 11:03 PM   #76
rideblue00
rideblue00's Avatar
Re: 66 SPID sticker language - share and learn!
Keep up the good work guys! this is great stuff.
rideblue00 is offline   Reply With Quote
Old 02-15-2013, 09:25 AM   #77
Keith Seymore
Keith Seymore's Avatar
Originally Posted by yelmer View Post
]here are some assembly photos i post these before so you may have them
Thanks for posting those; that would be the area I supervised some 15 years later.
From body drop to hood set; I had 37 hourly employees and 27 productive operations, including box tighten, spare tire hang, shifter install, underhood wiring (and battery install) and fender set.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-15-2013, 03:04 PM   #78
60-66
60-66's Avatar
Here's the documents from my 66 C10, finally got the build sheet out of the back of the seat, protectoplate and found a picture of it with a pop up style camper. Truck was used for hunting in Utah I believe.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-15-2013, 03:45 PM   #79
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
All I got out of my truck was a rock! lol
Could you scan your build sheet?
Old 02-15-2013, 04:01 PM   #80
60-66
60-66's Avatar
Sorry Aero, scanner quit on me but heres the closeups.
Old 02-15-2013, 04:04 PM   #81
60-66
60-66's Avatar
I should note the printing is whats blurry on the sheet.
Old 02-15-2013, 05:16 PM   #82
60-66
60-66's Avatar
You didnt get your 63 owners Protection Plan and manual packet ?
Old 02-16-2013, 02:15 PM   #83
aerotruk63
aerotruk63's Avatar
No such luck! I bought the books to put in my glove compartment. Along with the GM Tool Kit. I thought the books came in a plastic envelope?
Interesting paper envelope, is it litho in 1962?
I did however get a Registration from Penn Valley California and a pair of Black Plates.
Strange place for the Dinsmore Compass, I put mine above the rear view mirror.
Old 02-17-2013, 12:37 AM   #84
yelmer
here is ashot of the sticker behind the seat that i found for locker rear end
yelmer is offline   Reply With Quote
Old 02-17-2013, 08:16 AM   #85
rideblue00
rideblue00's Avatar
Does anyone have a build sheet from the St Loius plant they can share?
Old 02-17-2013, 01:03 PM   #86
aerotruk63
aerotruk63's Avatar
I purchased some 1966 dealer invoices. When I receive them, I'll scan and share them with you. Maybe we can break some of the codes.
Old 02-17-2013, 01:29 PM   #87
LT1 Burb
LT1 Burb's Avatar
I have that exact same sticker, I wonder if I could get it off in one piece.
LT1 Burb is offline   Reply With Quote
Old 02-17-2013, 03:28 PM   #88
cortcomp
cortcomp's Avatar
Post a WTB in the classifieds section, people have them for sale now and then NOS
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 02-18-2013, 08:53 PM   #89
60-66
60-66's Avatar
Photobucket just changed their entire site. Used to be able to post multiple pictures all at once, now can only do one at a time. Anyone else using the new photobucket ??
Old 02-19-2013, 09:19 PM   #90
jdl71
jdl71's Avatar
I just switched to it the other day and changed my avatar but haven't tried posting multiple pics since then. Is it not letting you copy more than one image tag or what?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 02-19-2013, 09:54 PM   #91
60-66
60-66's Avatar
I figured it out this AM, need to go in under settings to fix it.
Old 03-02-2013, 10:52 AM   #92
aerotruk63
aerotruk63's Avatar
I purchased some 1966 Truck Dealer Invoices. Scanned and sharing for those trying to break the code.
I also purchased some 1963 Truck dealer invoices. These have a single letter after the RPO. I've been working on those because in my world there's only 63! lol
Old 03-02-2013, 03:26 PM   #93
rideblue00
rideblue00's Avatar
Nice aerotruk63 !
Old 03-02-2013, 04:02 PM   #94
aerotruk63
aerotruk63's Avatar
I spent 5 hours going through the one's from 63. What emerges from the codes is the size of the truck 14/ 15/25/36 series has significance. What motor was ordered. Standard or Auto. Clutch. Color Combinations. Heaters, even found three different codes for the Radio...
For the radio's I thought of the differences, when there was one radio available. There were different motors requiring different brackets for the condensers and ground straps for a V8 compared to the inlines. This, I'm assuming.
The more your willing to share the info on yours or your buddys truck , the closer the accuracy of breaking the code.
Old 03-02-2013, 10:05 PM   #95
Keith Seymore
I see a lot of RPOs that were still in use during the '73-87 era (and today, for that matter):
C42 - heater
G50 - HD springs
M20 - trans
P13 - side mounted spare tire carrier
G80 - posi
for example.
K
1979-1986
1986 - 2019
Old 03-02-2013, 10:08 PM   #96
Keith Seymore
I suspect not; typically there would be different RPO codes for different "families" of radio: AM, FM, base radio tuner, manual pushbutton or whatever.
Different brackets and/or ground straps within the same family of radio would drive a different unique part number but would be below the "product planning" level of detail and therefore would not drive a unique RPO.
At least that's how it is structured today.
K
1979-1986
1986 - 2019
Old 03-03-2013, 03:39 PM   #97
aerotruk63
aerotruk63's Avatar
There was a single Manual Radio Option for the truck in 63, RPO U60, yet I have 3 different ECL codes for the radio. Could they have carried over the Tube type radio's from 62 until they ran out, then installed the new 63 transistor type radio's? Also notice different Condensor part numbers for different Alternator optioned.
Engineering Parts List Release was a reference to the individual parts required to add the option to the vehicule.
U60TH 6 trucks 1434 or 1534 with 230 or 292
U60TK 1- 1534 with 283
U60XX 1-2504 with 292
1966 Radio Codes.
Was there more than one Radio Option in 1966, or just a Manual Radio?
U60AA 1- 1434 with 250
U60AB 1- 25?4 with 292
U60AC 1- 25?4 with 292
U60BC 3- 15?4 with 283
U60BA 8- 15?4 14?4 with 283/ 327
WE need a lot more build sheets to confirm the findings.
Old 04-16-2015, 12:24 AM   #98
Bad4wd
I know this is an old subject, but I bought a 1966 k-10 truck without an engine.
I found the rpo codes behind the seat but the important part was missing.
I know it had a V-8.
What are the odds it came with a 327 in a 4x4.
Can you maybe tell by the rear end gears.
Maybe someone can figure it out. Here are the pics.
Thanks, Dave...
Bad4wd is offline   Reply With Quote
Old 10-27-2015, 08:19 PM   #99
rsd66C20
Bad4wd,
I'm pretty much a newbie to this site and to these trucks, but take a look at page 13 (Standard equipment) and page 14 (Optional Equipment) of your trucks vehicle information kit at the following site (Pick "Chevrolet Trucks (All Models Not Listed Below)" and 1966):
https://gmheritagecenter.com/gm-heri...tion-kits.html
Pretty much confirms that for a 1966 K10, the only V-8 was a 283. Also the 1966 owners guide confirms this in a couple of tables (Engine and Cooling System).
Hope this helps.
rsd66C20 is offline   Reply With Quote
Old 04-08-2016, 11:37 AM   #100
fsc66
There is a lot more to ECL codes than you would think. Just as an example, the 1966 Full Size Car had 18 different ECL codes for the U60 radio option. Some options have in excess of 100 ECL codes on cars.
If you want to educate yourselves on the complexities of ECL codes pick up a copy of Nolan Adams, The Complete Corvette Restoration Guide Vol II: 1963-1967. He lists each ECL code for every option with a usage column that explains the idiosyncrasies of each one. Yes, this is for Corvettes but it opens up your eyes to the trigger mechanisms that help differentiate the multitude of ECL codes for each option.
Expensive book but a great education.
Paul Winvoices.com
Here's just 1 link to the name of the book:
The Complete Corvette Restoration and Technical... The Complete Corvette Restoration and Technical...
fsc66 is offline   Reply With Quote
