Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 11-04-2003, 09:26 AM   #1
jmld16
Need Engine Bad
I have a 90 1500 with a 4.3 6cyl 5speed and the engine blew. I was told to put a 350 in and was wondering if anyone has a good used one up for grabs. Also will the same tranny work or will i have to change that to if I go with the 350. Thanks in advance.
1990 Silverado C1500
1984 Custom Deluxe 10 ( soon to be restored)
jmld16 is offline   Reply With Quote
Old 11-04-2003, 07:34 PM   #2
xJAZZILLAx
Will race for cash
xJAZZILLAx's Avatar
yeah it should work, i have a 5.7 i just pulled out of my truck it has a spunm main bearing, your more than welcome to it for a small fee. without the heads or cam
92 chevy stepper,4-bolt flat top 350, Aeromotive carb bypass regulator, holley 650 dbl pumper ,edelbrock performer intake, .530 .545 hyd bump stick, 3/8 sis, guideplates, 2.02 1.60 manley valves,tci street fighter t350 b&m 2500 stall, 3.73 richmond
xJAZZILLAx is offline   Reply With Quote
Old 11-08-2003, 01:59 PM   #3
DelRay
DelRay's Avatar
jmld16
I have a 305 HO short block(It ran when taken out of trans-am)It is a standard shift engine,that should be freshened up,bores are real nice,just put in rings and bearings and it will be fine(clean-up and hone the bores easy for the ring brake in)I can sell it for $100.you only live 4 hrs from me.this should be picked up.
If you go another route becareful of what you buy.you can't put a stick flywheel on an automatic trany engine steve
DelRay is offline   Reply With Quote
