Old 02-16-2013, 07:50 PM   #1
72restorationvirgin
Active Member
72restorationvirgin's Avatar
Question How to polish stock steering wheel??
How/what do you use to polish a stock 72 black steering wheel? It's in good shape with no major cracks and I don't want to repaint it.
67 C20 283/4 Speed
72restorationvirgin is offline   Reply With Quote
Old 02-16-2013, 11:03 PM   #2
72 tigger
72 tigger's Avatar
Re: How to polish stock steering wheel??
I use a fine rubbing compound to clean mine up- seems to work well
72 tigger is offline   Reply With Quote
Old 02-16-2013, 11:07 PM   #3
72restorationvirgin
Active Member
Do you remember the brand? Is regular Turtle Wax Rubbing Compund/Heavy Duty Cleaner to rough?
67 C20 283/4 Speed
Old 02-17-2013, 09:55 AM   #4
It's probably not too rough,but if it doesn't give the results you want you just move on to a finer polish. It can't hurt. The more coarse compound will make quicker work of the worse areas. I use that Nevrdull for final polish. It's cloth with polish in it and comes in a dark blue tin can
www.nevrdull.com
Old 02-17-2013, 03:46 PM   #5
hayhauler71
hayhauler71's Avatar
I used a high speed polisher that I use to buff my paint with the same 3 step polishing compounds I used on my truck. 3M foam pad 3M compounds
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 02-17-2013, 04:42 PM   #6
72restorationvirgin
Active Member
Ok thanks guys. What kind of high speed polisher do you have? I need to buy one....
67 C20 283/4 Speed
Old 02-17-2013, 07:19 PM   #7
cdowns
cdowns's Avatar
MCGUIRES has a product for cleaning and polishing plastic type stuff PLASTIX i use it on a whole bunch of things very easy to use and handbuff friendly gives a nice clear bright shine to alot of things
Old 02-17-2013, 09:40 PM   #8
hayhauler71
http://atdtools.com/10511 I have this one and has treated me well but bought 3M pads
Fuzzy
Old 02-17-2013, 09:44 PM   #9
Gumby
Gumby's Avatar
PLASTIX on a foam pad on a drill, great for cleaing up music or game disc also, from not working to mirror smooth very quick.
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 02-17-2013, 09:45 PM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
I would use a product such as the 3M Finnesse-it polish and if nothing else a good rag and hand rub it. The high speed may work, but since you are a novice it could burn the plastic and cause a distortion. I have two different polishers that I use. I have a Makita buffer that is variable speed and I also have a porter-cable buffer. They both have the adapter from 3M on them and can take numerous pads, form a wool bonnet to a soft foam pad.
Frank
Old 02-17-2013, 11:55 PM   #11
72restorationvirgin
Active Member
Thanks everyone. I'll get some Plastix to try tomorrow.
67 C20 283/4 Speed
