![]() Join Date: Sep 2006
Anybody know if u run a 295/40/20 tire on a wheel with 5.5bs if it will rub
going with 3/5 drop wanting to run 20x10 with 5.5bs mounting a 295/40 tire if it will miss the wheel well
![]() Join Date: Aug 2008
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: Anybody know if u run a 295/40/20 tire on a wheel with 5.5bs if it will rub
It will fit just fine, heres my old truck with 20x10 Coys with 5 1/2" backspace and 295/40/20's.
Down......with the sickness!! |
What year model truck? I am going with the same size tire however the rear end on my 70 is a bit narrower. Travis suggested a 4.25 bs on my incoming Vintecs
1970 Chevy swb, project UGHH! ![]() 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
#4 | |
The wheels I'm using are Superperformance Shelby Daytona Coupe wheels and the backspacing is net after the pin drive adapters: |
crawdadfox what is the wheel and tire size on the front and what is your drop..
I like your "old" truck bro! Is that a 4/6 drop?
![]() Join Date: Jan 2011
Assuming from your forum name - your truck is a 1970 model?
The reason I ask is there are two different axles in these trucks. In 1967 up through the end of 1969 and SOME 1970 model trucks (early production) the trucks had a 55.5" rear end housing in them. When I say 55.5" I am measuring from the inside of one backing plate to the other. This will just keep you from having to take the wheels off, you can lay under the truck and have a buddy / wife hold one end. In 1970, they started changing them over to a longer rear housing. Using this same measurement the longer housing is 57". You really need to know which housing you have. Crawdad's truck is a 71-72 (can't tell.. 71 I think) so I am 85% sure the rear end housing is 57" wide. In his example, the 5.5" BS will work, and it's sweet as hell. This is one of my favorite trucks on the forum. What if you have the 55.5" housing? That wheel would not sit the same. It would be tucked under the truck another .75" either side. IF you happen to find you have the more narrow axle (more desirable really) you can run a 5" BS on your wheels. This makes the wheel look wider ![]() Same size tire will be fine.. 5" on a narrow (55.5") housing, 5.5" on the later / wider (57") housing. The 5" BS wheel will offset this difference for you. While not the end of the world if it's 1/2 off but 5.5" on a narrow housing truck would sit pretty far under the wheel well and I'm thinking would probably rub the inner bedsides. (never tried it personally) With a 70 model truck it's a roll of the dice. My 70 GMC has the longer housing but I have seen 70 with the shortie. Just sayin, you might want to check.
i had a 3" spindle 1" spring in front and a 2" spring and 2 1/2" block in back. Front was a 20x8 1/2" with a 255/40/20.
