Dangerous situation, need some help please
I have a 1978 K30 Crew Cab that I have been getting back on the road. I'm having an issue where if I take a fairly sharp turn at a little bit of speed (15-25mph), the truck will start a very violent wabble, like the tires are going to fall off. If I slow down to a crawl it stops and then I can continue on and it rides great. It doesn't do it on slower turns or the sweeping highway turns and so far it's only done it on right turns. I made sure all the wheels are on correct and the lugs are torqued down. The tires are radials and in pretty good shape. Figured it wasn't a tire since it straightens out. Best I can tell everything is connected throughout the suspension and nothing appears broken. Any ideas? It's pretty scary.
Thanks, Patrick |
Re: Dangerous situation, need some help please
Is your suspension stock?
-Rus |
Best I can tell it's stock.
I can tell you that I was driving a buddy of mines truck, and when I hit a bump, or took a rather fast turn the same thing would happen until i slowed down. When i got below 10 it would go away just like you said... It ended up being his wheel bearing... Not to mention the damn things were less than 6 months old...
Its known as death wobble the whole front axle will jump around.As how to fix it i don't know on a leaf spring truck but some on here will tho.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
I had a bronco that did that. Turned out to be a wheel bearing. I found that out after the whole locking hub assembly blew out.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Something else after checking those ball joints/king pins, and wheel bearings, consider adding a steering stabilizer. The "Death Wobble" has been talked about a lot on solid axle trucks on other sites. It isn't just a GM, Ford, or Dodge issue, but happens with some solid axle trucks. After doing the Dana 60 solid axle swap from the Dana 50 TTB, I added the stabilizer and could really tell the difference. I don't know for sure what the wobble is from, but from what I understand it is caused by the steering parts wearing out quicker than other parts because of the stresses put on them.
1965 Chevy short-step side, work in progress.... ............................____ ..................______l/___\____ .................|_/(0)\_ll____/(0)_l. |
Thank you for the input everyone. I'll go through and take a look at the bearings and a stabilizer.
#9 | |
It's more of a Dana60 thing than just blaming it on "straight axle". It happens because of the difference in the ball-joints. The D60 doesn't have the traditional ball-joints like the D44 or GM 10 bolt does. It has a tapered (roller) bearing for the lower and a similarly shaped solid slug in the upper. The uppers are "spring loaded" under that 4 bolt cap. IIRC, someone makes a shim kit to eliminate the spring? But I haven't messed with a D60 for many years.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Thanks LONGHAIR, I ran across the springs online earlier. I'll have to see what "fixes" are out there.
