Old 02-20-2013, 10:07 AM   #1
65Gregg
65Gregg's Avatar
Who has done the 5 lug axle swap
I'm trying to find who you got your axles from, I see prices all over the place and checking to see if I'm missing anyone. All I will need is axles as I have drums etc from my current 5 lug 72 rearend but I'm going to rebuild the original 65 housing to gain a little tire clearence. I'll probably change to a 3.73at the same time, thanks in advance.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 02-20-2013, 10:17 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Who has done the 5 lug axle swap
Look at Summit Racing for Moser axles.
They have good prices.
Buying direct from Moser is also an option.
Keith
Convert to disc brakes.
Old 02-20-2013, 10:17 AM   #3
shawno72
C/10 junkie
shawno72's Avatar
I got mine from summit through eBay. Made by Moser and were $272.90 shipped to my door. Check my build thread, just installed them last week.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-20-2013, 10:34 AM   #4
65Gregg
65Gregg's Avatar
Thanks! I'm on the way to eBay
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-20-2013, 10:35 AM   #5
Reyals Bemus
Just bought my Moser conversion axles through Summit. Very happy with them. Since you have a '65, these axles will go right in no problem. Since I have a '64, I had to change the spider gears to 30-spline.
http://www.summitracing.com/parts/msr-a3065gmt5
Reyals Bemus is offline   Reply With Quote
Old 02-20-2013, 11:13 AM   #6
shawno72
C/10 junkie
shawno72's Avatar
Here is the item number 390544588849
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 02-20-2013, 11:25 AM   #7
65Gregg
65Gregg's Avatar
Dang you guys are good!
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-20-2013, 11:28 AM   #8
shawno72
C/10 junkie
shawno72's Avatar
Just trying to help
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 02-20-2013, 11:33 AM   #9
wayno
So do they not make the moser's for the 64 or do you have to change the spider gears?
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 02-20-2013, 11:35 AM   #10
shawno72
C/10 junkie
shawno72's Avatar
I'm not sure if Moser does it not buy I know ECE sells a kit that comes with the spider gears. Go to earlyclassic.com
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 02-20-2013, 12:26 PM   #11
Reyals Bemus
Well I talked to ECE when I was looking into converting my '64. They did NOT sell the spider gears. I bought the Moser axles listed above plus a spider gear kit sold by Superior. Both through Summit. Worked well.
Old 02-20-2013, 02:24 PM   #12
wayno
64 is a transition year from what the guys at ECE told me... it really depends on whether you have the 17 spline or 30 spline - their kit is only good for the 30 spline - so what your saying Bemus makes sense
Old 02-21-2013, 01:26 PM   #13
65Gregg
65Gregg's Avatar
I ordered the Moser axles from Summit and a Richmond ring and pinion, installation kit and new axle bearing/seals from Rons Machining( extremly nice and helpful). Both offer free shipping, thanks for the suggestions to all who replied.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-21-2013, 09:56 PM   #14
GVDobler
GVDobler's Avatar
What am I missing? The extra tire clearance? I recall that somewhere they changed the width of the rearend, but I guess I thought it was after '72. What year was the change made and what are the widths?
Also, did you already change the front to 5-lugs and discs.?
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
Old 02-21-2013, 10:07 PM   #15
Reyals Bemus
Dobler, I'm pretty sure the width change happened in '70.
Old 02-22-2013, 12:55 AM   #16
SCOTI
SCOTI's Avatar
Correct.... My understanding is that mid year '70, the width increased .75" each side to better match the wider front track width of disc brake set-up starting in '71.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-22-2013, 01:05 AM   #17
Captainfab
60-66 Nut
This is my understanding as well.
Old 02-22-2013, 01:11 PM   #18
65Gregg
65Gregg's Avatar
As it stands (or sits), I can't pull my rear wheels off without dropping shocks and coils to allow the rearend to drop down enough. I have about a little fingers clearance between the wheel well lip. I hope the additional .75 per side will alleviate the problem. I probably wouldn't be doing this right now but I had an axle seal go this past weekend and I have to tear everything down to do the repair so I figured just fix the old one since it's out and on the ground. The repair should go a lot quicker and with less down time.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-22-2013, 09:23 PM   #19
brokenspoke
brokenspoke's Avatar
I know you already bought your axles....however when I did mine it used 72 axles and took to a machine shop and shortened mine 3/4 inch per side...cost me 35 bucks
brokenspoke is offline   Reply With Quote
Old 02-22-2013, 10:17 PM   #20
65Gregg
65Gregg's Avatar
The upside is I will have a complete 72 rear end still left over as a backup or to help cover the cost of all the parts I ordered.
Have you given anymore thought on a date to try and do the HAMB meet at Holder's? Are you going to Hoedown?
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-22-2013, 10:22 PM   #21
mgchevyparts
mgchevyparts's Avatar
Why didn't you just redrill your stock axles from 6 to 5 lug (at machine shop)?
mgchevyparts is offline   Reply With Quote
Old 02-23-2013, 07:29 AM   #22
brokenspoke
I'm patiently waiting for some sunshine on a Saturday afternoon
Not sure on the Hoedown yet...
Old 02-23-2013, 10:49 AM   #23
65Gregg
65Gregg's Avatar
The stock axles are 45 plus years old and have some wear in the seal area, now I'll have everything new for another 45 years. :-)
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-23-2013, 07:50 PM   #24
brokenspoke
You did good
Old 02-24-2013, 01:38 AM   #25
Captainfab
60-66 Nut
With the axle being the inner race for the wheel/axle bearing, that area does tend to wear also. Any money spent on modifying worn axles would be better spent on new axles IMO. If your axles are not worn at all, then by all means modify as needed and use them, but that is typically not the case in my experience.
Wise decision
