Old 02-21-2013, 08:26 PM   #1
Gene
Gene's Avatar
Re: alternator wire up
Originally Posted by 71badblue View Post
gene after u wired up the alternator did u plug the voltage regulator back in? and do i need to run the wire that hooks into the stud with the bolt to the postive side of my battery?
No, the external regulator is not used anymore. Don't remember the particulars but you run a jumper at the plug. Follow the instructions in that thread and you'll be pleased.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
