Low Hump / High Hump
I've got a 71 fact auto with a low hump and a 72 fact 4 sp with a high hump. The high hump is bolt in removable and the low hump in the 71 is not removable and part of the floor. I'm converting the high hump truck to an auto and would like a low hump. Can anyone confirm the low hump is available in a bolt in? I though I had this in previous truck owned but not sure. Thanks.
Re: Low Hump / High Hump
I believe all low humps molded in
72 GMC super custom. ![]() |
Thanks - Was thinking that but was hoping to get proved wrong.
There are others I'm sure will chime in
It probably would not be that hard to cut out a low hump floor and weld a flange strip to allow it to be bolted in like a high hump yet with a low crown.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
