![]() Join Date: Feb 2012
big block oil pan
I need to buy a oil pan for my 70 1/2 ton. I need to know if the stock 7 or 8 qt big block pan will fit in my chassis?
![]() Join Date: Jun 2012
Re: big block oil pan
My 402 with stock pan fit fine and my later 454 with stock pan also fit OK. My stock pans only hold 5 quarts
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
The pan I am looking at is from a c-30 or bigger so the base of the pan is not square. It is a rectangle and would move it closer to the x member.
Vidman, your stock 454 pan Holds 5 quarts? is that the standard?
Dan 1968 Longbed Stepside C10 |
Yes 5 qts is standard. I just do not have a pan ( my pan was to rusty) and have found one local but its the 7 or 8 qt pan. I just wasn't sure how close to the x member it would be.
My 454 is actually a repurposed natural gas water pump engine. To withstand the temps out here it had a 16qt pan on it with an external cooler so now I need to nab a pan as well.
I know all the other 7-8 quart pans that i have used on trucks fit the application. Maybe someone will chime in that can give you a yes or no. if my motor was in the truck I could at least give you some kind of measurment..
a pic woul;d be nice if someone had one. I amoing to look at the pan inthe morning so I will just have to take a chance.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I have a big pan on my BB with no issues. If you are not in a hurry sometime this coming weekend I will go under and take some pics.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
i would first go to the autoparts store or GM dealership and check the cost of a new replacement oilpan and matching oilpump pickup b4 goin junkyardin
