Old 02-21-2013, 12:42 AM   #1
blkcorvair
blkcorvair's Avatar
TH400 Conversion E-Brake Cables Questions
I understand that when you move the crossmenber to the TH400 Location with the TH400 Trans that the e-brake cables route a bit different. Looks like the inyermediate cable goes through two loops on the cross member. It looks like those loops would be easy enough to fabricate, but does anyone know is the only difference in the cables the actual Intermediate cable? I found a TH400 specific Intermediate cable at Classic Parts.
Does anything else need to be changed? Thanks!!!
blkcorvair is offline   Reply With Quote
Old 02-21-2013, 10:20 PM   #2
blkcorvair
blkcorvair's Avatar
Re: TH400 Conversion E-Brake Cables Questions
ttt
Old 02-22-2013, 09:02 PM   #3
JimKshortstep4x4
The crossmember that I used on my recent installation has two loops but I have seen crossmembers with one loop. The installation is like your description
. I did use two of the wire cable guides to keep the intermediate cable centered in the holes that are in the crossmember where the cable goes through.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
