Old 02-22-2013, 10:02 PM   #1
Bloodyjaws88
Question Rear suspension swap opinions wanted
Hello all. I have a 69 longbed that I bought a couple of weeks ago. It has a leaf setup on it now. I also am picking up the 67 that donated its bed to my truck. The 67 has truck arms. The 67 is just a stripped cab and frame. Is it worth swapping the trucks arms in place of the leafs? My 69 will be getting a big block in the next couple of years. I may do some hauling with the truck, pulling my Camaro around. Which suspension set up would you folks use if you had the choice? Thanks for your opinions. Chris
Bloodyjaws88 is offline   Reply With Quote
Old 02-22-2013, 10:16 PM   #2
buckskins4ever
buckskins4ever's Avatar
Re: Rear suspension swap opinions wanted
I love my arms.....but I also am running a full bagger system so all coils are gone and replaced with bags. I am pushing right at 380HP and no wheel hop...and suspension feels solid.
buckskins4ever is offline   Reply With Quote
Old 02-22-2013, 10:33 PM   #3
Tinkermc
Arms and bags are a tough ticket to beat.
Tinkermc is offline   Reply With Quote
Old 02-22-2013, 10:47 PM   #4
Bloodyjaws88
Thanks for the arms/bags votes. Don't think I want to run bags. I guess I'm looking for opinions on ride quality and cornering ability. I'm planning on around 500-550 hp out of the 496 I'm going to build for her. Its not going to be a drag truck or anything. Just something to thump around town in. Chris
Old 02-22-2013, 11:09 PM   #5
BigCountryx
BigCountryx's Avatar
The frames are different I believe
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 02-23-2013, 03:01 PM   #6
1low
If u are hauling around that Camaro quit a bit I wood stick with leaf springs.
But coil spring would be a better ride
1low is offline   Reply With Quote
Old 02-23-2013, 03:35 PM   #7
GTJ558
I noticed that alot of people do bags and arms...i went with a 4"drop coil the arms and an adjustable trac arm and sway bar front and rear.... wheel hop i am not so sure yet i didnt get a relocator kit for shocks as of yet I will see how it feels but i prefer static style with the arms myself.
GTJ558 is offline   Reply With Quote
Old 02-23-2013, 04:30 PM   #8
Bloodyjaws88
Thanks for the opinions guys. I think Ill probably swap to the arms. How difficult is this swap as far as crossmembers go? Do I have to swap them or should I just weld the arm brackets onto my current crossmember? I may put bags in the rear to help when hauling the cars around. Is there anything else I should think about? I don't have both frames side by side yet, so I can't really compare them. Thanks again guys. Chris
