Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-24-2013, 04:17 PM   #1
tc4x4
tc4x4's Avatar
What welder should I get.
How big of a welder do I need to do ANY welding that will come up on my truck build? From welding thick frame pieces to welding thin body pieces. What welder should I get? Or would be best for this type of welding.
Project Second Life----1978 c35
http://67-72chevytrucks.com/vboard/s...d.php?t=503961
tc4x4 is offline   Reply With Quote
Old 02-24-2013, 04:29 PM   #2
Low84
Low84's Avatar
Re: What welder should I get.
I bought a welder not too long ago, just getting around to learning how to weld. That said, obviously I don't have the knowledge to make a good recommendation. BUT I can tell you that Hobart is a good old fashioned company that stands behind their product 100%. It's actually a rebadged Miller.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 02-24-2013, 04:30 PM   #3
tinydb84
tinydb84's Avatar
The shop I used to have access to had this: http://www.lincolnelectric.com/en-us...olnElectric%29
Expensive but bad ass.
This will be the next welder I buy: http://www.hobartwelders.com/product...ed/handler190/
David
Instagram: myfabguy
Old 02-24-2013, 04:39 PM   #4
tc4x4
tc4x4's Avatar
That hobart is nice. It says it welds up to 5/16 think. How think is a frame on one of our trucks?
Old 02-24-2013, 05:58 PM   #5
vidman
vidman's Avatar
If you are just buying it for your build there is no need to spend the big bucks on name brands. I have had good luck with the Miller and Hobart machines. The only thing that I do not like about the Hobart Handler is it has the 7 position voltage switch. Other machines like the Miller have a infinite voltage switch which some people prefer. Any 180 class Mig machine will work for your build. I have a miller maxstar 200 that I use for stick and tig, Millermatic 211 and a lincoln weld-pac 125. We use Miller machines at work and I feel it is a better all around machine..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 02-24-2013, 09:25 PM   #6
MadManAndrew
I have a Hobart, hasn't failed me yet.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 02-24-2013, 09:38 PM   #7
71swb4x4
71swb4x4's Avatar
I have a Hobart 140 and it is awesome. I actually spent more money on my helmet than I did on my welder. I can buy a new welder if needed, tough to buy new eyes though!!!
If you want to weld frame you would do better with a 180. One of my clients has a 140 and he has built trailers and skid steer attachments with his, but he is VERY experienced with his welder. There isn't much room for error when using a 140 on heavy stuff, you have to know exactly what is going on.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-24-2013, 09:40 PM   #8
tinydb84
tinydb84's Avatar
The hobart will handle he frame with ease. I think ours our 3/16? and I know some people when boxing their frame go to 1/4
David
Instagram: myfabguy
Old 02-24-2013, 09:58 PM   #9
VH Coachworks
VH Coachworks's Avatar
You can't go wrong with a Miller product, we have used Miller welders exclusively for the past 25+ years at our shop and couldn't be happier with them. Everything from plating, frame fab, body panels, and whatever else that we throw at them; the Miller will handle it's job with ease.
With that being said, I would recommend going with a 220V MIG unit. If your not an experienced welder, MIG is a lot easier to learn with then a Arc or Tig unit. Not to mention that it is much easier to control your heat dispersion with a MIG versus a Arc welder.
VH Coachworks is offline   Reply With Quote
Old 02-24-2013, 11:33 PM   #10
Rochlow
I bought a Hobart 140 about a year ago with a 250ci plasma. Did all my cab work with it and I love it!
Rochlow is offline   Reply With Quote
Old 02-24-2013, 11:50 PM   #11
wyattglock
wyattglock's Avatar
I used a Hobart 125 Handler for a full year before I finally found a Miller 140 Autoset on CL for a steal. The Miller is a Cadillac compared to the Hobart, but it is also 10 years newer and has a lot more technology integrated into it. Not to bash the Hobart, it was a steady performer with consistent results. The biggest thing I noticed that helps both of these 110v welders is an isolated circuit. I have a high amp 110v circuit that I put in my garage when I drywalled it. Makes a huge difference not having any other draw while using the welder.
wyattglock is offline   Reply With Quote
Old 02-26-2013, 07:07 PM   #12
Kabwe
Certified Car Nut
Kabwe's Avatar
If I were you, I would get a nice 220 welder. I have a Hobart 180 and I use it for everything from sheetmetal repair and fab to frame work. I have a Miller tig welder also but the Hobart is still my work horse.
Kabwe is offline   Reply With Quote
Old 03-02-2013, 11:34 AM   #13
lahnen
if your set up or able to set up 220v go with one of those, supposet to be easier on your electric bill also. i got a hobart 140 and i love it.
lahnen is offline   Reply With Quote
Old 03-03-2013, 01:06 PM   #14
Mr. 250r
Mr. 250r's Avatar
I've measured 1/2t and 3/4t frames and i never found them to be different they all come in at 3/16in i believe while the 1 tons come in at 1/4in and taller but not sure how much but onto your dilemma. Personally i would find something can weld about your max thickness so assuming your only ever going to weld... say 1/4in i wouldn't buy a welder that is maxed out at 1/4in but that's just me here is a thread with me reviewing the millermatic 211 http://67-72chevytrucks.com/vboard/s...d.php?t=560453, i haven't finished it and im still messing around with it and yes for small welding projects its expensive but i prefer miller as they have not let me down yet
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 03-23-2013, 04:43 PM   #15
da_bears_da1
Very happy with my Lincoln 180C.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 05-28-2013, 12:23 AM   #16
jc70chevy
jc70chevy's Avatar
love my weldmak 140 for small jobs like my cnotch
jc70chevy is offline   Reply With Quote
Old 05-28-2013, 09:17 AM   #17
vin63
It's Better With Nitro
vin63's Avatar
Not to get into a brand war, I have a 185 amp TIG welder that I use for most of my welding projects. I also have a 140 amp MIG welder of the same make/brand that I use for smaller sheet metal panel projects.
jc70chevy, is the weld for your C-notch above porous, or is it just the lighting during the photo (it looks like there are voids in the bead)? If it's porous, I would have that re-welded since it's your frame.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-28-2013, 10:22 AM   #18
ERASER5
ERASER5's Avatar
I am very happy with my Thermal Arc 3-1 181i. Out of the box it can Stick or MIG and can be upgraded to TIG.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-28-2013, 11:58 PM   #19
_Ogre
_Ogre's Avatar
i used a 120v fluxcore welder to do most of this
the thickest metal on a truck is 3/16 max, any 120 volt welder can weld 3/16 steel
shop air compressor timer
