Old 02-18-2013, 10:08 PM   #1426
shadow1967
shadow1967's Avatar
Re: Kabwe's aka Bam's build
Originally Posted by Kabwe View Post
Nope that would not work. I may have grew up in Los Angeles but my family is Southern in nature.lol I drive a truck as a daily driver. My grandfather believed that no man should be without a truck.lol
My Grandfather was from Florida and said the same thing!
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 02-18-2013, 11:28 PM   #1427
Daze57
Daze57's Avatar
^ thats it !!!!!!!!! plain and simple
Daze57 is offline   Reply With Quote
Old 02-25-2013, 02:12 PM   #1428
Kabwe
Certified Car Nut
Kabwe's Avatar
Well since I have not posted pics in a while I thought I should no matter how small the mod is. I knew I had to raise my bed floor 2 inches due to my c-notches. I looking in metal yard for some scrape tubing and I could not find anything I liked, I decided to make some my own 2 inch spacers. I try to keep things simple it makes my life easier. Of course I will have to move the angle strips on the bed up 2 inches so that bed sits in the same spot as factory.
I will use the bolt to hold the washers in place and then weld it together.
Here is one of the spacers completed. I will need six of them for the three cross sills.
It will lay on the frame (I'm undecided if I will weld them to the frame or not) Its not structural so it really does not make a difference, but I am leaning towards welding them.
Here are some misc pics of the 4 link reinstalled with the fuel and brake lines.
Kabwe is offline   Reply With Quote
Old 02-25-2013, 02:40 PM   #1429
oldman3
oldman3's Avatar
Really like the way the frame looks, nice job. I agree on welding to frame, one less thing to line up when installing bed for the final time...Jim
oldman3 is offline   Reply With Quote
Old 02-25-2013, 02:52 PM   #1430
Daze57
Daze57's Avatar
lookin good
Old 02-25-2013, 06:11 PM   #1431
Kim57
Kim57's Avatar
Nice fab work Bam.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-25-2013, 09:08 PM   #1432
OrrieG
OrrieG's Avatar
Looks good. Did the neighbor notice his missing fence post?
Old 02-25-2013, 09:19 PM   #1433
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by Daze57 View Post
lookin good
Originally Posted by Kim57 View Post
Nice fab work Bam.
Kim
Thanks guys.
LOL. SHHHHH be quiet I don't think he will notice.
Old 02-25-2013, 09:46 PM   #1434
_Ogre
_Ogre's Avatar
how are you going to handle the tailgate x-member?
step up at the tailgate?
sort of wish i had raised my bed...
shop air compressor timer
Old 02-25-2013, 09:51 PM   #1435
Kabwe
Certified Car Nut
Kabwe's Avatar
The only thing that would be raised is the bed floor. When I move the angle strips up two inches that bed will mount factory but the bed floor will be raised. The last cross sill and tailgate will be in the same spot. There will be a two inch gap when I open the tail gate but I fab something up for cosmetic reason when the time comes.
This is a extreme case, my gap will only be 2 inches but you can get the idea.
Old 02-26-2013, 07:28 AM   #1436
dug224
dug224's Avatar
Headed in the same direction. Don't understand how the spacers are "not" structural. As usual, nice work...dug
dug224 is offline   Reply With Quote
Old 02-26-2013, 10:18 AM   #1437
youngrodder
youngrodder's Avatar
Kabwe-
I had a simular gap issue with my raises bed. I just welded in a panel and tied it into my rol pan. When my tailgate is down (which is almost never) it is nice and clean. Just sharing ,I know that you will come up with something slick.
Nice progress.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-26-2013, 10:52 AM   #1438
Kabwe
Certified Car Nut
Kabwe's Avatar
I may have worded it wrong, what I meant was that bolting it or welding it will not affect the structural integrity thats all. The tubing is 3/16 thick and the washers where added to align with the holes in the frame and to stop any lateral movement and once bolted and sandwiched between the frame and the cross sills it will fine. I still think I going to weld them because I'm known to lose things and its one less thing to lose.lol
Originally Posted by youngrodder View Post
Kabwe-
Nice progress.
Marc
That's exactly what I was going to do. Beautiful truck man.
Old 02-26-2013, 08:36 PM   #1439
VDOG
Grand PooBaa Member
VDOG's Avatar
Ok im totally lost. But whatelse is new. Now why are you raising your bedfloor, isnt that to lower the bed when using airbags? I know you were doing a static drop and not using big wheels on your truck. So is it a clearence issue with something?
Lost as usual.
VDOG is offline   Reply With Quote
Old 02-26-2013, 08:37 PM   #1440
BlueJeep
BlueJeep's Avatar
I did similar, except I had a new rear sill bent up to my specs, which was then butt-welded to the stake pockets so that I didn't have the overlapping metal (which caused the original stake pockets to rust through).
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-26-2013, 09:26 PM   #1441
Kabwe
Certified Car Nut
Kabwe's Avatar
Lost as usual.
It is correct that you are always lost, but I consider you my hot rodding responsibility. I am your Lieutenant Dan and you are my Forrest Gump so I will explain things clearer so that you may understand Forrest. Remember when I redid my c-notch for more clearance? Well because I did higher c-notches I now have to raise my bed floor 2 inches for clearance or the bed floor will hit the c-notch. Are you caught up now Forrest.lol
Sorry Vdog but I had to.lol
It looks great man, good job.
Old 02-26-2013, 10:34 PM   #1442
Baldeagle SR
Bam you mention about a grinding disc that will shrink metal. I have been in a closet for about 20 years. I called the parts house today and they didn't know what I was talking about. Could you tell me what or where I can get one of those disc. Thanls Rich
Baldeagle SR is offline   Reply With Quote
Old 02-26-2013, 10:46 PM   #1443
Jesse49chevy
Jesse49chevy's Avatar
Lol.....is it comedy night?
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline   Reply With Quote
Old 02-26-2013, 10:46 PM   #1444
Jesse49chevy
Semper Fi
Old 02-27-2013, 10:13 AM   #1445
Kabwe
Certified Car Nut
Kabwe's Avatar
Its called a skrinking disc. I like the smooth ones you can buy them all day long on ebay. Practice on some scrap metal first. When using it don't use any pressure let the disc do the work.
Jesse49chevy
Your are crazy, hows that truck build going?
Old 02-27-2013, 10:23 AM   #1446
Jesse49chevy
Me crazy? heck your the comedian!! it was pretty funny though..
the build is coming along, i visited my dad a week or so ago and he is so far ahead on the body, he told me to come pick it up in April as he plans to be done with it.
So that only means one thing, i better put it in gear and finish the chassis.
Ive been working on the rear, installing the leaf springs i bought (Explorer) but im having second thoughts about it, Im tore up between it and a 4 link setup. I dont intend to bag it, i just want a nice mean stance, but really im not to confident on how it will turn out. And the only reason im thinking about the 4 link is because of how it can be adjusted to ensure it is square.
but then again, i have this thing called BUDGET.
Semper Fi
Old 02-27-2013, 10:33 AM   #1447
Low Elco
Sunchaser Tools makes the shrinking disc. You need a big grinder. Works great!
Low Elco is offline   Reply With Quote
Old 02-27-2013, 01:52 PM   #1448
Kabwe
Certified Car Nut
Kabwe's Avatar
Vdog is my buddy and we just go there with one another, its all in fun.lol
There is nothing wrong with leaf springs. Just go with them now and change it out later if you still want to do that. A flip kit should get you low enough and if not you could always add a lowering block. If you still want a 4 link at a later date, well thats why we say they are never done.lol
Old 02-27-2013, 09:19 PM   #1449
VDOG
Grand PooBaa Member
VDOG's Avatar
Lieutenant Dan: I am not a smart man, but I dont know what hotrodding is and its not a box of chocolates. LOL
Bunch of clowns on here. LOL
Old 03-01-2013, 08:28 PM   #1450
Kabwe
Certified Car Nut
Kabwe's Avatar
Well I had a little time today so I decided to go ahead and weld the bed floor spacers to the frame.
Just checking cross sill bolt alignment.
Finished and repainted.
Before I mount the bed I have to move the angle strips up two inches and bed should fit like factory but the floor will be two inches higher.
