creator of kong
OK, stay with me here, if you can......
There is a male plug (orange and white wires), coming out of fuse bos, for lighting interior......I also have a rear cargo light. The cargo light harness has 1 male and 1 female plug.the dome light has 1 female plug.....the 2 under dash lights have 1 fm plug (2 total) and the harness that connects them has 2 female and 1 male plug....the harness that connects the door pin switches has 1 male and 1 female plug.....Every time I try to run everything together, I run out of plugs.Everything does piggyback onto each other...right? I can either leave out the under dash lights, or the dome light, to make it work....I know there has got to be a way to wire them all up...please help |
creator of kong
ttt
is there white and orang eon the cargo lamp also ? are 67-72 cargo designed ot operate with the door switches, or only with manual switch ?
maye if we could understand how its ssupposed ot operate then we could figure out how it needs to be wired. ------------------ Randy- Lincoln, IL randy@ccaonline.com -71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it- -'84 Z28 H.O. 305 L69 700R4 GT4 3.73 - 1984 Firebird SE 2.8L T-5 GT4 3.73 -1981 Cutlass Supreme, dunno what im gonna do with it yet... -79 G20 pass van, 350/th350/10bolt *Paint is overrated © RSS Enterprises 2000 |
creator of kong
yeah, cargo light has white and orange wire, just like dome and underdash lights.....cargo light also has piggy back connection, like it goes in line with something else.....Randy C-10 just told me if I need to, just to add the needed connection myself, which I believe I am going to do....I will run the cargo light from the hot in the fuse panel, so it has power to the switch all of the time, regardless of doors being open or closed....I am then going to run the piggy back to the door switches, then to the under dash lights and splice my dome lamp into this, so it will be hot when door opens.....wish me luck
