Old 02-27-2013, 03:34 PM   #26
BULLITT65
BULLITT65's Avatar
Re: Little help needed: original 1964 C10 front suspension?
Well most likely you will just go through pads. The rotors will probably not really "wear out". Do you have 71- 72 chevy truck calipers ? just wondering if when you switch rotors, if you will have to switch calipers?
If you lived in the states I would just trade you. I have the rotors with the 5x5 bolt pattern.
If we can figure out what you have, I would love to go down the street to the auto parts store and buy a new set right off the shelf.
Let me know on your calipers, I am wondering if my chevy truck ones are going to work with your rotors. thanks
BULLITT65 is offline   Reply With Quote
Old 02-27-2013, 05:12 PM   #27
BULLITT65
BULLITT65's Avatar
You will likely just go through brake pads, the rotors will probably not wear out.
Do you have 71 - 72 chevy truck calipers as well ? Just wondering, to see what calipers fit the rotors you have and if a caliper swap may be needed as well. I hope this is a simple bolt on, since I have the 2" drop spindels for a 70 -72, I also have the 5x5 bolt pattern rotors. If you lived in the states we could just trade!
I am excited to know what these rotors are.. it would be nice just to go down to the auto parts store and pick them up.
Old 02-28-2013, 02:07 AM   #28
nibulus
nibulus's Avatar
I'm pretty sure I have 71-72 calipers as well, since they perfectly mount on the spidles.
Theoretically it could be possible that GM engineered some other model with different size calipers (e.g. for a smaller rotor diameter), but still use the same mounting points as the C10, and thus allow one to mount calipers from that other model on a C10. I think it's quite unlikely though.
nibulus is offline   Reply With Quote
Old 03-14-2013, 02:04 PM   #29
nibulus
nibulus's Avatar
Right, here are some pictures a requested:
Old 03-16-2013, 03:50 AM   #30
BULLITT65
BULLITT65's Avatar
Hey thanks for the pictures. It looks like it may be a 2 piece rotor in that side picture? does the flange with the wheel studs come off?
Old 03-17-2013, 03:54 AM   #31
nibulus
nibulus's Avatar
I'm pretty sure it doesn't. I obviously had it off when mounting the new spindle and had a look at it back then. It seemed to be a regular one piece rotor.
