Old 02-27-2013, 10:04 AM   #476
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project "Just an Old Truck"
Originally Posted by shawno72 View Post
Anytime you wanna come and cruise with us, you would be treated as family. The more trucks the merrier and everyone is such a great group of guys and gals.
Well, with this government sequester thing looming I might have some spare time on my hands. My visit might be sooner than later!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-27-2013, 10:16 AM   #477
shawno72
C/10 junkie
shawno72's Avatar
Hey make it in April and you can do the C/10 Club BBQ with us
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-27-2013, 09:39 PM   #478
C10_ustacould
Tonight I did a little post install rear end check. Topped off the fluid, and reinstalled the 3.5° shims Hart_Rod loaned me, I had a little vibe on the round trip to work today. Going to drive it again tomorrow, hopefully it will check good. Waiting to hear back from the guys at Porterbuilt about a trailing arm crossmember to fix the goofy wheel well issue. If I can get that settled the next big project will be the crossmember and forward arms.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-27-2013, 11:52 PM   #479
shawno72
C/10 junkie
shawno72's Avatar
What kind of vibe are you getting? Ever since the 700 install I get a very light vibe under hard acceleration. Just enough to notice.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 02-28-2013, 12:23 AM   #480
C10_ustacould
At around 55-60 it is a mild vibration that you feel in the seat (does that make sense?) and between 60-65 it gets worse. It's not felt in the steering wheel, seems to be isolated to the rear. I had the shims in before the rear end swap and it seemed better, but I wanted to start fresh so I would know what eventually fixes it. I am hopeful that a PB adjustable trailing arm crossmember will do the trick! We'll see.
As for your your truck, I think it is tire shake from all those ponies your trying to put to the pavement!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-28-2013, 09:14 AM   #481
C10_ustacould
Morning drive report... Well, installing the shims seems to have created a new vibration. This is actually a good thing because it gives me something to compare and contrast. The vibration I have been fighting may simply be in the wheel balancing, because it is more of a shudder in the whole truck that eminates from the rear. This new vibration is more of a buzz at 35 and 55. I guess I will remove the shims and see if the new vibration goes away. No matter what, vibration or no vibration, it was a great drive to the job today.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-28-2013, 09:29 AM   #482
lolife99
67-72 parts collector,…
lolife99's Avatar
Have you put an angle finder on the trans and rearend?
Just wondering where you are at.
Keith
Convert to disc brakes.
Old 02-28-2013, 10:27 AM   #483
C10_ustacould
The trans was 5° down before I raised the tail shaft about an inch and the rear end was 0°. I am going to have to put it up on the set up blocks tonight and remeasure everything again to varify, if I were to estimate I would think the trans 4° down and the pinion is 3.5° up with the shims. Where I may get into trouble is if the pinion is higher than the transmission (from the ground) causing the angles at each universal joint to exceed the 4° limit.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-28-2013, 10:30 AM   #484
shawno72
C/10 junkie
shawno72's Avatar
Curious to see where you end up degree wise. I have never even messed with the angles of the trans or rear end and its super smooth until I get on it. Even then it's a very slight wiggle in the seat. Prob just leave it be.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 02-28-2013, 10:32 AM   #485
C10_ustacould
If that is all you have I wouldn't sweat it. My problem is that I avoid driving my truck over 60 mph because the vibration worries me...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-28-2013, 10:49 AM   #486
54belair
54belair's Avatar
Nice project----love 68's
I can definitely relate to all the parts being stashed all around! Ive got a 3 bay shop and my truck is currently using 2 bays plus some storage out back!
Ill keeping watching for sure...
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 02-28-2013, 09:08 PM   #487
C10_ustacould
Checked my angles and here is what I found. The transmission is 3.5° down, the drive shaft angles up 1.5° toward the pinion, and the pinion is 3.5° up. The transmission output shaft is .500" (1/2") lower than the than the pinion. Total angle at the output shaft is 5° and the total angle at the pinion is 5°.
Based on what I have read there should be no more than 4° total angle at any universal, and the output shaft and pinion angle should be the same (or close). My total angles at each Universal are 1° over the limit, but my output and pinion angles are identical. Are the total angles my issue causing my vibration?
Here are the pics I took, as well as a layout of the angles... Pic 1) Output Shaft 2) Drive Shaft 3) Pinion 4) Angles on paper (helps me visualize)
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-28-2013, 09:30 PM   #488
lolife99
lolife99's Avatar
If you a re going to swap the trailing arms or trailing arm crossmember,... I would work on it then.
Fixing it now,... may change when you swap parts later.
Keith
Old 02-28-2013, 09:38 PM   #489
C10_ustacould
As always Keith you speak wisely. But, I don't like the new vibration that showed up today so I am going to pull the shims with the hope that it will go away. I just want to be able to drive it until I can swap the trailing arm crossmember. I hope the adjustability offered with the PB unit will allow me to tune the angles and find the sweet spot.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-28-2013, 09:44 PM   #490
lolife99
lolife99's Avatar
Have you driven it much with the rally wheels on it?
I wonder if that would confirm "wheel balance" vs driveline.
I know the shims created a new issue,... just wonder if you should try your rallys before you pull the shims?
Keith
Old 02-28-2013, 09:51 PM   #491
C10_ustacould
I understand what you are saying... Pondering it.... Not sure the rally's will fit the rear with the long rear end.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-28-2013, 11:01 PM   #492
DIRTY HAIR
very nice build!
DIRTY HAIR is offline   Reply With Quote
Old 02-28-2013, 11:20 PM   #493
C10_ustacould
Originally Posted by DIRTY HAIR View Post
very nice build!
Thanks!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-01-2013, 02:04 AM   #494
C10_ustacould
Swapped out the "modified" proportioning valve for a CPP disc/disc unit, test drive in the morning.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-01-2013, 10:26 AM   #495
C10_ustacould
Wow! The proportioning valve made a huge difference, $40 bucks well spent.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-01-2013, 10:30 AM   #496
shawno72
C/10 junkie
shawno72's Avatar
Amazing how everything hinges on those little bugers
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-01-2013, 10:55 AM   #497
C10_ustacould
Yep, after I installed the new one I dug into the old one and found the little valve the CPP instruction said to remove to convert my old one to disc/disc. However, the fluid path for the rear brakes is much larger in the new proportioning valve so it has to be much more efficient. Anyway, it was worth a try!
I snapped a pic on my way out to the truck after my breakfast stop at Whataburger...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-01-2013, 11:11 AM   #498
Rusbuilt
Rusbuilt's Avatar
Whatatruck!! lol
Rusbuilt is offline   Reply With Quote
Old 03-01-2013, 11:12 AM   #499
C10_ustacould
Originally Posted by Rusbuilt View Post
Whatatruck!! lol
Hey that was post #500!! Woo Hoo!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-01-2013, 11:16 AM   #500
Rusbuilt
Rusbuilt's Avatar
Awesome lol
