02-21-2013, 12:47 AM | #1 |
Just here to tinker
Suburban side window gaskets
OK, I know that we've mentioned this several times but I cannot find the thread.
Where is a place that sells the side window gasket sets? I've seen the website but cannot remember which one it was. HELP!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
02-21-2013, 02:34 AM | #2 |
Re: Suburban side window gaskets
Got ours from Truck and Car Shop out of Orange,CA...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
02-21-2013, 02:45 AM | #3 |
This is where we get our stuff from, great people to work with and they have everything!!!!
http://www.truckandcarshop.com/6072.html Edit: You beat me to it!! I got distracted looking through their catalog...
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck |
02-21-2013, 03:45 AM | #4 |
I just looked at their catalog and it appears they sell two types: A "replacement type" for $25 ea, and "original design" for $169 pr.
which did you get and have you inspected them or tried installing them yet? |
02-21-2013, 08:41 AM | #5 |
1961 crewcab
I think steele rubber might be the company that makes/repros the originals??
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-21-2013, 11:09 AM | #6 |
Just here to tinker
Thanks guys! Rocktonka, does that kit have everything to completely rebuild the sliders? How did the quality look to you?
02-23-2013, 10:31 PM | #7 | |
Posted via Mobile Device |
02-24-2013, 12:35 PM | #8 |
Sad to say if you want to do it right it's going to cost you. I steer away from packaged kits because they tend to not fit right. I got my rubber gaskets from steele rubber and they weren't cheap but they are quality, but that's all you get. The glass run channel and the beltline have to be purchased seperatly. C.R.Laurence makes these products and they are also quality. The glass run is 10G96 and the beltline is YM372, the only change you have to make is on the vertical piece of beltline that slips into the small channel. The stainless bead has to be removed for it to fit properly. It's easily removed with a pair of needle nose pliers. The C.R. Laurence products can be purchased at your local glass contractors or supply outlet. You can also buy and view the pieces at Restoration Specialties online.
02-24-2013, 01:42 PM | #9 |
I got mine from Steele back in the 90's, but I think Bob's Truck Parts in Mesa, AZ has them as well. Not sure about Bob's quality, but I'm going to get my liftgate/tailgate w/strip from him eventually to see how they are.
02-28-2013, 10:03 PM | #10 |
Just here to tinker
Care to comment on the quality? Does the kit include all of the parts to completely rebuild the sliding windows?
03-01-2013, 01:09 AM | #11 |
Oops, forgot I had posted that here. We haven't pulled them out of the bags yet to check them out. We believe that we ordered everything that we needed to replace ALL the seals/gaskets in the burb. Probably going to be a bit before we get around to that...I don't remember paying too much for what we got So we probably have the ill-fitting flavor.
