Old 03-01-2013, 02:05 PM   #1
DBear
DBear's Avatar
K30 Front Leaf Spring Help
Does anyone know what the factory front leaf springs under an '85 K30 look like? The frame I picked up for my build has a set on the front that really doesn't look stock....they are a 4-leaf pack. Here is a couple of pics...they seem to be maybe lift springs. Thanks in advance
DBear is offline   Reply With Quote
Old 03-01-2013, 02:15 PM   #2
rs74
rs74's Avatar
Re: K30 Front Leaf Spring Help
Not sure if this will help you or not but here is my 84 K30 C&C. It has 4 leafs on the front.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-01-2013, 02:22 PM   #3
DBear
DBear's Avatar
Those look similar....but still seem to have some lift to them.
Old 03-01-2013, 02:27 PM   #4
rs74
rs74's Avatar
Mine look sprung out of shape to me. I would think for being a K30 there would be more leafs myself. Of course I am sure it depends on what the trucks GWVR or whatever it is, is rated at.
Roy
1987 R10 shortie
Old 03-01-2013, 03:30 PM   #5
86c20
86c20's Avatar
i will have to check mine but i think it only has 3 and its the hd gvw. could be wrong on the lelfs.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 03-01-2013, 04:11 PM   #6
Keith Seymore
Keith Seymore's Avatar
I don't have time to read right now; see if it says something about how many leafs in here:
http://www.gmheritagecenter.com/docs...olet-Truck.pdf
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-01-2013, 04:30 PM   #7
DBear
DBear's Avatar
I check those out a lot for info, but they dont ever list how many leafs....I wish they did though...thanks for the idea.
Old 03-01-2013, 07:56 PM   #8
donut
donut's Avatar
Seems to me some on-line spring stores listed the number of leafs.
I was shopping for my old K-20, that had 3, listed the K-30 at 4.
I did try 2 extra leafs. 8' snowplow only dropped the nose 1/2" and rode worse than a buckboard. Those 2 leafs are sitting on the scrap pile now.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 03-01-2013, 08:02 PM   #9
GM72K10
Next!
GM72K10's Avatar
The stock K30 military CUCVs have 3 springs in front. when its light I will get you pics of my 83 K30 and My 86 K30 dump.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 03-01-2013, 09:19 PM   #10
pwradder
pwradder's Avatar
i had a similar question when i first bought my truck, brought it to a guy i know whose seen, and owned, and worked on a lot of these trucks and he says that original springs will have a negative arch and lift springs are either flat or have a positive curve in them, depending on the amount of lift. installed in the truck of course. hope this helps.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 03-01-2013, 10:31 PM   #11
DBear
DBear's Avatar
Thanks for the replies guys......very helpful.
GM72, thanks for the picture and when u get a chance i would like to see the others too!
Old 03-02-2013, 01:56 PM   #12
GM72K10
Next!
GM72K10's Avatar
These Both are factory 3 leaf setups, first is a 83 K30 dually pickup, second is an 86 K30 dually C&C (my dump truck)
86 K30 CUCV M1028A1
Old 03-02-2013, 02:21 PM   #13
justcuz
justcuz's Avatar
Yep 3 leafs are stock, any more than that are added leafs by previous owners. You can usually tell the difference especially with an add a leaf since they don't usually follow the contour of the stock springs.
justcuz is offline   Reply With Quote
Old 03-02-2013, 04:15 PM   #14
rs74
rs74's Avatar
If you look in my photo above why does only one leaf wrap around the bushing and it has 4 leafs. The other photos of the three leaf has two leafs that wrap around. What is the difference there. Since mine has four then that means that it is rated for more weight?
Roy
1987 R10 shortie
Old 03-02-2013, 05:57 PM   #15
donut
donut's Avatar
rs74 , Your spring packs "may" have been fixed. My K-20 did come with 3 leaves and 2 wrapped.
What's the rating on the front end? Does the build sheet show HD suspension?
http://www.truckspring.com/suspensio...1985&model=K30
They show different leaves for the front, depending on weight rating. Just like rear springs, how many are in the pack?
My K-20 did have the HD package, more than likely due to the dealer installed snowplow.
Old 03-02-2013, 06:38 PM   #16
rs74
rs74's Avatar
Not sure what it is rated at. When I bought the truck it had the glove box mixing so no SPID sticker. I haven't seen anywhere else where the rating would be stamped.
Roy
1987 R10 shortie
Old 01-13-2025, 11:47 PM   #17
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Warning - old thread revival.
Just doing some research about K30 front springs and this post has about the best discussion I found.
So, I thought I'd leave a pic of Pierce Manufacturing's idea of the spring "enhancement" needed for my 1982 K30 brush pumper / firetruck. I count the factory "maximum" pack of 3, plus 3 more thicker leaves that...well, don't exactly improve the ride.
We'll see how it sits after I get all the extra gear removed; maybe I can pull one or two leaves.
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is online now   Reply With Quote
Old 01-15-2025, 12:38 PM   #18
kwmech
Original poster has theoretically a factory pack, but there is an added leaf that is factory from another leaf pack. May have been installed from a snow plow company or something similar. Never seen, from the factory, a 4 leaf pack. The second poster is just an add-a-leaf. For your issue, I'd pull the bottom extra leafs and see where it sits, then maybe add back the center one that's curved in the front if needed and go from there. When I converted my Suburban to 1 ton, I initially went with a 4 leaf pack that I took to a spring shop to have them rebuilt and straightened out. I ended up taking the bottom leaf out as it has lifted the front too high and stuck with the 3 pack
