Old 03-01-2013, 03:58 PM   #1
gotsand30
Swap questions..
Ok.. well its been a while since I posted.. still check out these cool trucks and build threads regularly tho, some u guys are really talented... anyways here are my questions.. I have a 2 wheel drive 63 c10.. I wanna swap out to disc brakes and possibly auto column shift.. so what brakes and column would be a fairly easy swap? Thanks again for your time and keep up the amazing work on these trucks.._
gotsand30 is offline   Reply With Quote
Old 03-01-2013, 09:28 PM   #2
Clyde65
Clyde65's Avatar
Re: Swap questions..
71-87, all you need to do is swap the upper/lower A arms, spindle and brake stuff. Get the per steering from te same donor and get capt fans adapter for the gear box to frame and the per booster to cab.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
