03-01-2013, 05:14 PM | #1 |
Chevy 3600 with Blazer Rear End....help!!
Found a newer GU6 coded blazer rear end that I wanna install.
My question revolves around the driveshaft/ rear end mating. I assume I will use my driveshaft. Is there a universal joint that attaches my driveshaft to the Blazer rear end? |
03-01-2013, 05:17 PM | #2 |
Re: Chevy 3600 with Blazer Rear End....help!!
Your running the SM465 transmission still?
Reason I ask is because if you have to get a drive line made (like I had to), just cut the end off the driveshaft for the rear end and bring that. I am running a Ford 8.8 out back so I had to have it mate up with my NV3500.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
03-01-2013, 05:20 PM | #3 |
If that is the stock 3600 4 speed then yes. Enclosed back to hanger bearing then open.
03-01-2013, 06:01 PM | #4 |
Should be a 1310 u joint at the rear, get the conversion joint to the blazer rear and you are done. Any parts store should have the number , or I can go through my reciepts
03-01-2013, 06:04 PM | #5 |
My stock rear end is HO52 correct?
So I need a conversion joint to go to a HO52 to connect to the driveshaft, and the Blazer? Is the Blazer u Joint a 1310? |
03-01-2013, 08:44 PM | #6 |
1350-truck to a saginaw s44 -Blazer. Carquest Scott 541-998-6882 P/N 2-1153 in stock and can ship to you.
sorry it took so long, that was a wierd one Last edited by NEWFISHER; 03-01-2013 at 08:45 PM. Reason: that was a tough one |
03-01-2013, 08:47 PM | #7 |
Your the man Fish!!!
03-02-2013, 12:25 AM | #8 |
Also to help others......a Precision #447.
My local O'reilly's had one in stock!! |
