Old 03-01-2013, 01:29 PM   #26
61K10
61K10's Avatar
Re: So mad !! new tranny did not bolt up !!!
speedo gear------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-01-2013, 01:43 PM   #27
cori 64
cori 64's Avatar
I would not waste my time with a th350 !!Put a 700r4 in it!!if i had a 700r4 right now you could have my th350!!
cori 64 is offline   Reply With Quote
Old 03-01-2013, 01:55 PM   #28
cori 64
cori 64's Avatar
And my engine is in the rear position and i have a one piece drive shaft so another 3 inches forward with a 700r4 and boom no more prius passing me on the freeway!!
Old 03-01-2013, 10:30 PM   #29
sevensixoh
sevensixoh's Avatar
ok so I took off the original flywheel and its a 14 inch 168 tooth flywheel. the flywheel did not bolt up to the th350 torque convertor , so I guess I need a new one. also I took a pic of the bolt holes on the block , is this a staggered or straight bolt pattern ?
sevensixoh is offline   Reply With Quote
Old 03-01-2013, 11:49 PM   #30
losthope
losthope's Avatar
this may help clarify what holes to use ,cant tell withe all the grime what you have for holes but looks like you have at least a staggered setup ,look at the link if your block has both holes threaded besides the blue circled hole you should be able to use either style starter and corresponding plate:
http://www.crankshaftcoalition.com/w...tarter_pad.jpg
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 03-02-2013, 12:39 AM   #31
Dano0579
Dano0579's Avatar
Since we are talking about trannies, does anyone know if a 1991 s10 5 speed manual transmission will bolt up to a 1962 235 i6 motor? Thanks for any help.
Current project (My Maria)
62 Chevrolet LWB stepside
235 inline 6 cylinder
http://67-72chevytrucks.com/vboard/s...d.php?t=569873
Dano
Dano0579 is offline   Reply With Quote
Old 03-02-2013, 02:13 AM   #32
cori 64
cori 64's Avatar
pretty sure the t5 will !! look in the faq section!!
Old 03-02-2013, 02:35 AM   #33
Dano0579
Dano0579's Avatar
The T5 is that what that particular transmission is called? Sorry for the dum questions but i sure don't know. Thanks and I will look in the question part.
Dano
Old 03-02-2013, 11:56 PM   #34
Captainfab
60-66 Nut
The bellhousing bolt pattern and size is different than the '63 and up I6's and all small blocks and big blocks. So you will need to keep your original bellhousing.
Old 03-03-2013, 12:53 PM   #35
Dano0579
Dano0579's Avatar
Thanks for all the help guys. It has been very helpful. Now all I have to do is find a Brog Warner T5 and I will be good to go. Thanks all.
Dano
