Old 03-03-2013, 04:30 PM   #1
flatbed51
flatbed51's Avatar
Old school farmer sheetmetal repair.
Here is some pictures of a truck I picked up last weekend for parts. Sheetmetal repair has sure improved over the years !!
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 03-03-2013, 04:36 PM   #2
theastronaut
theastronaut's Avatar
Re: Old school farmer sheetmetal repair.
Wow!! That's a little extreme! Wonder why didn't they just swap out for a used fender.
I just repaired a pair of fenders that weren't that bad but had been poorly repaired. Patent date of April 13 1920 is stamped on one of the riveted pieces!
theastronaut is offline   Reply With Quote
Old 03-03-2013, 04:58 PM   #3
reinmeister1951
I have had similar fenders, they are a great learning experience but if you value your time it is cheaper to buy a new aftermarket fender. But I would do it again in a heartbeat.
Doug
48 chev LWB pickup 350 turbo400 tri power
48 GMC S10 350 700R4
48 che 5 window 2012 Camero suspension & power train
reinmeister1951 is offline   Reply With Quote
Old 03-03-2013, 05:32 PM   #4
FarmerSid
FarmerSid's Avatar
I'm seeing that right now on my build. Not as bad but is a fun learning experience. feel the same as you Doug.
FarmerSid is offline   Reply With Quote
Old 03-03-2013, 05:41 PM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
That riveted one might have been a fairly good quality repair in a rural setting, pre the welders-are-commonly-available era.
Back in those days if you want to cut out & replace, did you braze in the repair? I'm sure it took a fine touch with an oxy/acetylene torch.
Dan in Pasadena is offline   Reply With Quote
Old 03-03-2013, 06:12 PM   #6
Rude Dude
Rude Dude's Avatar
Hey Dan, I still dig out my torches and welding rod when I have a small sheet metal crack that needs welding just for practice!
Rude Dude is offline   Reply With Quote
Old 03-03-2013, 07:45 PM   #7
Russell Ashley
Russell Ashley's Avatar
Those fender welds look pretty standard for old farm truck repairs. Usually you didn't braze it, you straightened out a coat hanger and used it for your welding rod. My Dad was a welder and we never bought any rods for acetelyne welding when I was growing up.
Russell Ashley is offline   Reply With Quote
Old 03-03-2013, 07:59 PM   #8
flatbed51
flatbed51's Avatar
Thats exactly what these welds were, I did many of the same back in the day of farm implement repair. What am I saying I even did on many of my early rods. I still have a collection of wire hangers ready haha !!!!!!!!
My Build Thread
51 chevy
Old 03-03-2013, 08:10 PM   #9
Dan in Pasadena
Maybe its a dumb question but do these coat hanger repairs stand up over time without cracking? I assume its a low heat weld?
Old 03-04-2013, 09:06 AM   #10
Russell Ashley
When you are acetylene welding a fender or some other part you try to keep the heat down as much as possible, but you have to get the metal to the melting stage or it wont fuse together. As far as holding up, if you cleaned the area around the weld good and painted it it held up fine. I think most of the famous customs from the fifties and sixties were done with acetylene and they are still around. Guys like Barris and Winfield probably used coat hangars too.
Old 03-04-2013, 11:54 AM   #11
reinmeister1951
Back in the day coat hangers were made with better quality steel, these days they are made from crap. Mechanics wire works great and leaves the joint soft for metal finishing. Just remember to clean it before welding.
Doug
