"BETSY" - 1964 C-10 Longbed / Step Side
Cause size matters
![]() Bought this a couple of weeks ago and want to do a nearly frame off restoration / custom job on it.. I've managed to break parts on the inline six already so i'm par for the course on the projects. pics to come |
Re: "BETSY" - 1964 C-10 Longbed / Step Side
Pics on pickup day
#3 | |
If you don't break any parts your not tryin' ![]() I started out with a mild resto in mind.,, and, well,,,,, things just happen. Welcome aboard Subscribed. |
So second weekend of tear down and I've found some rust. This was defintely someones previous project. THey skipped a few steps when it came to prep, so ive got more body work to learn how to do. Looks like fender patch panels will be needed.. Question to the group, if the rust is minor, is there any other way to repair other than cut and and replace?
Went to the swap meet Saturday morning at Atl Dragway and came away with some nice trim pieces for final assembly. One other question, Any ideas how to remove a VERY rusted lower fender bolt? Ive got everything else out, but the big one on the lower section on both sides is seized up pretty bad.. If i ziz wheel it off, is a replacement hard to find? |
Here is my sketch for what i am going for.. a touch lower, but this is a starting point (couldnt find a long bed step template to "crayola" .. but it gets the point across
Another question, or poll i guess.. Keep the I6 and trick it out or SBC?
On the rusted bolt I use PB Blaster, shoot it and use a screw driver to pick out as much dirt as possible.
Re-shoot 2-3 times a day til it gives. Unless my patients wear thin then I use a propane torch to heat it up. Then it either gives or snaps off. I6 vs v8 depends on what your wanting to do. Personally I prefer v8's but thats just me. I may end up using an I6 on Bompenstein. On patch panel. Page 5 on my build I'm working with patch panel and home made patch panel pieces. Here are some builds that may interest you. http://67-72chevytrucks.com/vboard/s...d.php?t=457465 http://67-72chevytrucks.com/vboard/s...d.php?t=474858 Here ya go. Looking good. ![]() |
