![]() Join Date: Jun 2009
Automatic Tilt steering columns
I have heard of these being used in the 60-66 trucks and it is nice to have a factory GM item compared to the pricey Ididits and Flame River columns. This is an EXCELLENT condition tilt steering column removed from a motor home. I actually have 2 of these. The one that doesn't have a neutral safety switch has the horseshoe connector. The other one has the flat connector. One has no neutral safety switch at all and never did. The other has a neutral safety switch but it is mounted higher up than the trucks. These are the same exact length as the 67-72 trucks. All parts are in great condition. Selector lens is nice and clear with no yellowing and includes a new gear selector pointer. Use as is or repaint for show quality. Tilt is nice and tight and works as it should. Automatic lever housing is in great shape with no play where the pin mounts and there are NO dents in the tube or housing. Turn signal cancels as it should as well. I have had several variations of this column for the 67-72s and these are as nice as any of them. Price is $225 not including shipping.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Re: Automatic Tilt steering columns
Hi question about these colunns do the 66 style wheel fit and work ok on them thanks
| Bookmarks |
