Old 10-23-2003, 07:57 PM   #1
HatGuy
HatGuy's Avatar
Question Remove and replace dash pad
Can someone tell me how to do this.
Please
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 10-23-2003, 08:45 PM   #2
pound41
Pull your glove box out. If you already have a new dash pad replacement you will see the threaded pegs that hold it in place. This will give you a good idea of where they are. Start undoing the nuts. Work your way across. Depending on how nimble you are you might have to pull the radio and the guages. It has those thin self cutting nuts like what some emblems have so you will need to get square on them. Pretty simple hope this helps
pound41 is offline   Reply With Quote
Old 10-23-2003, 10:30 PM   #3
HatGuy
HatGuy's Avatar
Thumbs up
Thanks Pound41
72' K5 Highlander
My Daily Driver
Old 10-25-2003, 03:58 AM   #4
HatGuy
HatGuy's Avatar
any other advice?
anyone?
72' K5 Highlander
My Daily Driver
Old 10-26-2003, 11:26 AM   #5
3wbdriver
3wbdriver's Avatar
Wish I could help, but i gotta do the same thing. Email me with results. Think of it as a courtesy to an exiled fellow Texan. I call Flower Mound home.
'72 Blazer, 4WD, 350/4 spd. Affectionately known as "Da Beast"
'04 Silverado (new daily driver)
'00 Intrepid (wife's ride)
It's a BLAZER dude! No options, no emblems, no a/c, no fancy shmancy. It's a BLAZER....
3wbdriver is offline   Reply With Quote
Old 10-27-2003, 03:47 PM   #6
Yukon Jack
Yukon Jack's Avatar
Sure helps to have the gauge bezel out too. They couldn't make them more difficult to get to!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-27-2003, 04:06 PM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I had to pull the Golve box, dash bezel & Light switch. Radio would be helpful to remove.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 11-11-2003, 02:58 AM   #8
SS55
Everbody has probably already got all of this dash pad business figured out but here's my tid bits of info.
If I recall correctly, there are four phillips head screws going through the dash pad into j-nuts on the lower side of the dash pad. On the firewall side there are nuts threaded onto the studs that are protruding through the dash sheetmetal from the pad. I do not remember the qty, but at least five. A couple of them are really hard to get to. The ones on the ends of the pad and the one by the wiper switch come to mind.
Anyway, hope some of this helped.
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight!
71 Blazer, ex-4WD...Bought it that way
55 GMC
55 Belair 2dr HT
67 El Camino
SS55 is offline   Reply With Quote
Old 11-11-2003, 01:25 PM   #9
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Like everyone else said, pull the cluster and glove box. I'm sure it will help to pull the radio, but I can't speak from experience on that since I don't have a radio (just a big hole thanks to a PO). It's also a good time to make sure all your wiring under the dash is nice and pretty too.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
