Old 03-04-2013, 08:08 AM   #1
Johnny Merder
Johnny Merder's Avatar
Missing Coolant?????????
I have a 2005 GMC crew cab 2wd with 5.3, coolant is being consumed about a quart a week. i have checked all the usaual deals, no visible exteriaor leak, no smoke or smell from exhaust, no wet passenger floor. I did pressure test system and it wouldnt hold pressure, it went from 15psi down to 5psi in 20 min. Any ideas?
Johnny Merder is offline   Reply With Quote
Old 03-04-2013, 10:12 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: Missing Coolant?????????
Head gasket, my yukon lost quarts over the years also but wasn't consistent.It would come and go but never caused any problems.
LT1 Burb is offline   Reply With Quote
Old 03-04-2013, 12:43 PM   #3
truckdude239
truckdude239's Avatar
Check the waterpump before condemning the motor ifthewaterpump is leaking it has time to burn off before showinga leak look forthe discolor of dried coolant
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 03-04-2013, 02:39 PM   #4
Justin87
Justin87's Avatar
The water pump should have a weep hole on the bottom which you should be able to see leaking or signs of it leaking if the water pump is bad.
2006 Silverado 2500 HD
Justin87 is offline   Reply With Quote
Old 03-04-2013, 06:35 PM   #5
bighaas79
I agree I have replaced dozens of water pump gaskets that the coolant would dry up off the front of the block from the heat of the engine, and not really leave a trace of leakage. Best way I have found is to get it up to op. temp. and pressurize the system, and watch the gasket area closely.
bighaas79 is offline   Reply With Quote
Old 03-04-2013, 09:38 PM   #6
Boog
laying low
Boog's Avatar
double click
Boog
Old 03-04-2013, 09:47 PM   #7
Boog
laying low
Boog's Avatar
Agree with bighaas. Water pump gaskets are prone to leak at times and dry before reaching the ground. Slow leakers but will eventually get worse. I just replaced the pump on my 2000 with 156,000 miles. Gaskets were leaking but then the bearing in the pump was going out also. Nothing from the weep hole yet however.
Boog
Old 03-05-2013, 09:59 AM   #8
Johnny Merder
I pulled all the plugs out last night and used borescope to inspect cylinders, everything looked great. I pressurized the system and it wont hold pressure, but I cannot find an external leak.
Old 03-05-2013, 08:20 PM   #9
Boog
laying low
Boog's Avatar
Check to see that the motor oil and tranny fluids are the right color and not overfull?
Boog
Old 03-06-2013, 08:16 AM   #10
Johnny Merder
I wish it was that easy to figure out, both the engine oil and trans fluiod are the correct color and level. I think I will pull the intake this weekend.
Old 03-06-2013, 01:59 PM   #11
bighaas79
Intake has no coolant going though it, not understanding this as your next step?
Old 03-06-2013, 08:28 PM   #12
Boog
laying low
Boog's Avatar
That's right. There is no coolant running through that intake manifold. The source of your coolant loss will be found elsewhere.
Boog
Old 03-11-2013, 09:36 AM   #13
Johnny Merder
Well, after pulling the intake I couldnt find any place the front TB passage was leaking into the runner. I went over everything with a fine tooth comb, my local dealer had mentioned that they had a couple that were leaking into the runner from the TB passage, but mine wasn't. Back to the drawing board......
Old 03-18-2013, 08:07 PM   #14
oldno7
oldno7's Avatar
i would check where lower hose connects to radiator you could have small holes in the radiator there and its leaking only under pressure while driving
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 03-20-2013, 01:29 PM   #15
69gmcc10
69gmcc10's Avatar
Did you check the water pump gaskets like truckdude239, justin87 and bigass79 suggested???!!!!! They are very prone to leaking on these trucks. My coolant was pulling a Houdini as well and the problem was the water pump gaskets.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
