Old 03-04-2013, 10:58 PM   #1
damianbryand
Turbo 400 question
I have a 68 C10 with a turbo 400 transmission. I just installed the driveshaft and linkage. It doesnt have a dip stick yet and I also need to put fluid in. I started the truck to see if it would go into gear but it didnt do anything. I didnt want to leave it running or try for very long because of the no dipstick and fluid so I only tried twice. I'm new to this so any help would be awesome!!
damianbryand is offline   Reply With Quote
Old 03-04-2013, 11:06 PM   #2
71 super
71 super's Avatar
Re: Turbo 400 question
Don't do that! Put fluid in and hope you have not already ruined the trans. Fluid is what makes the bands clamp which makes it shift. You may need a new trans.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-04-2013, 11:08 PM   #3
long67
long67's Avatar
It wont do anything without fluid. you need dipstick and fluid before running it.
Mark
67 c20 custom camper
55 Olds 2dr hardtop
96 mustang
11 dodge nitro
long67 is offline   Reply With Quote
Old 03-04-2013, 11:10 PM   #4
damianbryand
Crap ok. I honestly did it for 3 seconds so hopefully it's still ok.
Old 03-04-2013, 11:15 PM   #5
buckskins4ever
buckskins4ever's Avatar
I pray you didnt fry the bands or friction plates. place the dipstick in, filler up with good trans fluid, run it for a few minutes and then move from park to neutral slowly. Then try reverse.
Good luck.
buckskins4ever is offline   Reply With Quote
Old 03-04-2013, 11:18 PM   #6
damianbryand
Got it. It does actually have fluid but its needs to be changed. I do need a dipstick however....
Old 03-04-2013, 11:26 PM   #7
damianbryand
Didnt mean to scare anybody but I want to correct myself. It does have fluid but its old. I meant to say it didnt have new fluid. It does not have a dipstick so I was curious would this make it not engage?
Old 03-04-2013, 11:30 PM   #8
70cst
70cst's Avatar
That sounds much better.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-04-2013, 11:39 PM   #9
buckskins4ever
Thats a lot easier to handle. The Dipstick wont have anything to do with the shifting or engaging.....only determine how much fluids in it and if not seated good enough to seal at the casing it will leak. Now that being said, when you ran it with the current fluid, and no dip stick tube in place, did it leak out? If not odds are you still dont have enough fluid in it to make it engage. Or keep this in mind as well.......if the fluid is REALLY old it is possible the trans may already have a wore out band.
I would still drain out the fluid, and refill with fresh. Try it again, if not working then you should at least try to do a trans flush.
Old 03-04-2013, 11:43 PM   #10
damianbryand
No leaks at all. I have a dipstick coming tomorrow. I will put that in and drain the fluid and put some new fluid in. Thanks!
