The Older Generation
1967 Only, Show Quality, complete matched Lock Set
I have for sale a show quality matched lock set for a '67 Chevy pickup. This set includes a '67 only ignition switch (no accessory position) with the bezel and spacer. 2 complete door lock cylinders with retainer clips & new gaskets, and one ignition lock cylinder. The lock cylinders are all keyed to the same original Briggs & Stratton small octagon head keys, with a third aftermarket key for backup. The knockouts on the B&S keys are stamped with the '67 code number 7V07 that matches the numbers on the door and ignition locks. The locks are used but I have cleaned and lubed them and they work smooth. You don't get any more original than this.... The set may sound a little expensive but the spacer alone is worth 25 or 30 bucks because it is one year only and not reproduced. The bezel is nice but you may want to check into one of the new reproduction ones. I have the set priced at $50.00 shipped. PayPal or Money Order works for me. Per board rules post in thread before sending any PM's. Thanks for looking. LockDoc
Re: 1967 Only, Show Quality, complete matched Lock Set
Interested, sending PM
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
Sale pending to 67_ShortFleet.
LockDoc
Florida Edition
![]() ![]() Join Date: Oct 2010
I'll take it for 50 shipped if it gets to me Leon.
Brad
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
I'll Let you know either way Brad. Thanks. LockDoc
Active Member
![]() Join Date: Oct 2002
Can you do the same set up For my 1968, " C " code on the keys
Sold to 67_ShortFleet. Thanks
PM sent
Got them today. Thanks!
Thanks for letting me know.
LockDoc
