02-25-2013, 12:23 AM | #1 |
Help and advice needed with 65 C20
Hi
I just got a 1965 C20.I understand it was the camper but the back is missing.It is a good looking truck considereing age.I want to start changing it.Firstly lowering it. What is the lowest I can take it with just coils? Will that change stance and handling I am in South Africa,so parts is a bit hard to come by.What coils can I use? I would love to take it down 4-5 inches later this year if possible. Any advice and help would be appreciated. Thanks |
02-25-2013, 07:25 PM | #2 |
Re: Help and advice needed with 65 C20
First of all. welcome to the board!
You can buy coils up to 3" of drop, but you can save money and cut your stock coils. Each winding of the coil will give you between 1.5 and 2" of drop. I wouldn't cut more than 1 or 1.5 coils because if you cut any more, the ride will be terrible. For a nice ride and a good stance, I recommend 1 cut coil and a pair of drop spindles. Close to a 5" drop with very little geometry change. One thing to remember when you lower these trucks: the biggest issue is the ground clearance between the lower control arms and the pavement. Use the Search feature of this site, and you will find literally dozens and dozens of threads concentrating on nothing but suspension. It's great reading!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
02-26-2013, 12:18 AM | #3 |
Hi Chevyrestoguy
I was looking at your build threads yesterday and really like what you doing.Thanks for the advice.I will check it out today and see hou I can cut them for now,and start planning on the rest of the build.Thanks Jacques |
03-03-2013, 11:34 AM | #4 |
Ok,I have decided now that I want to slam the truck and get it into daily driver condition.
I understand that there are bolt on kits for 2.5 lowering spindles and then the lowered coils. Where can I find out if it will work on my C20 as everything seems to be for the C10s. Can someone send me some links for past threads as I can't really find in depth detail of what I want to do.Thanks guys! |
03-05-2013, 03:53 PM | #5 |
Please can anybody tell me where to get lowering kits for these C20's.It seems like all the kits are for c10's.What is the difference when it comes to their suspensions?
03-05-2013, 04:02 PM | #6 |
Great looking truck. Nicely optioned too.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
