Longer wheel studs dana 60?
Wondering if anyone's put longer wheel studs in there dana 60 front? The factory ones are 2.5 inches long I want to go 3-3 1/4 long ... I changed the rear out to a longer stud but looking to hear what anyone has used for the front and I want to stay 9/16. Thanks
86 gmc short box..461bbc/th400 12.95@106mph 85 gmc crew cab 4x4 8"lift cummins conversion ![]() |
Re: Longer wheel studs dana 60?
I cut down a set of dually hubs, I tried the dorman # 610 - 303 (3 inch) but had interference fit issues. I then went back to the stock ones Dorman part # 610 - 283 ( 2.5 ish) and they fit great. According to the specs on pirate http://www.pirate4x4.com/tech/billav...ont/index.html what I said does not make sense, but its what I ran into. When I drilled out the stud hole, (duallys are threaded) I may of went slightly oversize.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
