01-24-2013, 12:22 AM | #26 | |
Re: Anyone no what pistons these are??
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
01-24-2013, 01:30 AM | #27 | |
Yes, it does itensify with higher lift, higher valve spring pressures, and higher RPM. But it's always there. Bolt a set of splash gaurds on a set of rocker studs sometime and watch, you can see the gaurds twist even while turning the motor over with the starter. I've seen many "stock valvetrain", vacuum rule limited, circle track motors flex the studs like that. And we couldn't run anything more than a .510" (hyd flat tappet) lift cam to meet the vacuum rule in most cases.
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold *** First Ride <> '81 C10 Long Fleet *** Current Project *** |
01-24-2013, 02:03 AM | #28 |
Thanks for all the tips RWB! I've found out there is an art to it lol My father use to build a motor weekly. He built them around sound and not performance though. I ask him rpm questions or strength questions. His answer is normally around, when it comes to rpm, and strength, you no you went to far when it blows. Or when you here a bang lol
01-24-2013, 02:23 AM | #29 | |
Lol, I had a buddy who used to say something along the lines of "You wanna know how fast it can turn? Stand on it til it blows up. It was 1 less than that."
03-06-2013, 01:07 AM | #30 |
Yes, it does itensify with higher lift, higher valve spring pressures, and higher RPM. But it's always there. Bolt a set of splash gaurds on a set of rocker studs sometime and watch, you can see the gaurds twist even while turning the motor over with the starter. I've seen many "stock valvetrain", vacuum rule limited, circle track motors flex the studs like that. And we couldn't run anything more than a .510" (hyd flat tappet) lift cam to meet the vacuum rule in most cases.[/QUOTE]
Might want to check your valvetrain geometry- if you are flexing studs with a .510 lift cam something is off.... or maybe you were using the short thread ARP studs, ARP has several different thread lengths available.
