Do I have to grind to fit 16" aluminum?
So I've read the threads and articles about grinding calipers to fit 15-inch wheels. There is a really good article and tutorial about grinding the Dana 60, but I haven't found any really good pictures and tutorial for a Dana 44 (or Corp 10-bolt, since they use the same hardware on the outside).
But what about 16-inch aluminum rims? I don't have a set in front of me, so I can't tell if the 16-inch aluminum has a larger ID than a 15-inch steel. Right now, I have a 15-inch steel and they don't fit, they require a wheel spacer to clear the caliper. Anybody have experience or thoughts on 16-inch aluminum rims?
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
Re: Do I have to grind to fit 16" aluminum?
No problems on mine, they're 16".
71 K20 64 GMC mud truck |
16" aluminum rims will clear fine.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
20' Daredevil (Ret)
![]() Join Date: May 2003
For the record -- and for anyone wondering about fitting 15" steelies to a K20 -- my K20 has a Dana 44 front axle. Years ago when I got 15x8 wagon spokes, all it took was minor caliper grinding and the wheels fit okay without spacers. This was before internet so no pics, no tutorials, just a borrowed angle grinder and a few beers. Grind a bit, test-fit the wheel, grind a bit more....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#5 | |
What's the offset (or backspacing) of these 16-inch aluminum rims that you guys are using? My current rims stick out really wide, they only have about a 2.5 inch backspace, another half inch and they would clear the caliper even though they are only 15-inch wheels.
