Old 03-07-2013, 04:46 PM   #1
54blackhornet
54blackhornet's Avatar
Re: DIY Converting Alternators
OK You win ! Does any one make a plug in play harness ? I see one for head light relay upgrade's ? Or do you have to tear into your harness to upgrade to IR alt ?......thanks
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-07-2013, 05:43 PM   #2
MARKDTN
Do a bit of research before you convert to a CS130 alternator. The failure rate is very high. The CS144 is a much better unit. If you must use a CS130, only use a Genuine rebuilt by Delco unit. The generic rebuilds do not always (usually) do the upgrades on the bearings to make these live.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
