Old 03-06-2013, 10:55 PM   #1
Novalicious
Some help indentifying dropped spindles
No name or part # just c10 lh and rh
Novalicious is offline   Reply With Quote
Old 03-06-2013, 11:34 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Some help indentifying dropped spindles
If that is a bell to the lower left of lh or RH it's Belltech.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-07-2013, 01:51 AM   #3
eldogg
eldogg's Avatar
Looks like DJM or Chassis tech to me.
eldogg is offline   Reply With Quote
Old 03-07-2013, 07:04 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Not true.
Belltech has the word "Belltech" and the part number cast into each spindle.
Keith
Convert to disc brakes.
Old 03-07-2013, 07:05 AM   #5
lolife99
lolife99's Avatar
You'll have to check upper balljoint or outer tie rod fit to know for sure what year spindles these are.
Keith
Old 03-07-2013, 09:11 AM   #6
Novalicious
kind of figured.....Ball joint position is 12/6
Old 03-07-2013, 10:05 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
What Keith means is that you're going to need to go to the parts store with the spindle and test fit ball joints and tie rid ends to find the ones that fit the tapered ball joint and tie rod holes. It could be 63-70, 71-72, or 73-87 fitment. All will work on your truck if you swap parts accordingly.
Tx Firefighter is offline   Reply With Quote
Old 03-07-2013, 10:25 AM   #8
Novalicious
I know.....thanks. Thought I remembered the older spindles were laid back a little on the caliper location moving the ball joint orientation from 12/6 oclock to 11/5 which is why I included that. Don't remember if that is correct or not.
Old 03-07-2013, 11:19 AM   #9
LVPhotos
LVPhotos's Avatar
[QUOTE=lolife99;5932408]Not true.
Posted via Mobile Device[/QUOTE
Bought my Belltechs and that bell was the only marking. They were bought years ago but the rust on those would say same time frame.
Old 03-07-2013, 01:52 PM   #10
Novalicious
He is correct
Old 03-07-2013, 04:34 PM   #11
Tx Firefighter
That means they came from the Bell foundry. They cast spindles for different companies as well as Belltech stuff. They also cast the Super Bell axles for hot rods too.
Its the same thing as Western casting spindles for CPP, Early Classic, as well as themselves.
Old 03-07-2013, 04:43 PM   #12
Novalicious
Very cool learn something new every day. heading to parts store now....see what I can find out.
Old 03-07-2013, 06:32 PM   #13
Novalicious
73-87....Don't know the brand, but knowing they came out of Bell foundry I am more comfortable....
Old 03-07-2013, 08:26 PM   #14
lolife99
lolife99's Avatar
There are two 73-87 spindles.
Light duty 1" rotor version and the HD 1-1/4" rotor version.
Keith
