Old 03-03-2013, 10:12 PM   #1
50mercfan
50mercfan's Avatar
Side Moulding Clips?
who has the best deal for the good side moulding clips? i'm not going to use those plastic stick on deals. thanks
50mercfan is offline   Reply With Quote
Old 03-04-2013, 10:17 AM   #2
camrycurt
camrycurt's Avatar
Re: Side Moulding Clips?
Upper or lower moudling? Year?
I ordered mine from Classic Parts to put on my used set of upper and lower LWB 69-72 trim because they were the cheapest, and the lower clips were all excellent. They were indistinguishable from the originals and went on perfectly. The upper bolt on clips were also great and worked perfect as well.
The upper snap-in clips were another story. They were worthless. They were not at all like the originals and didn't work at all. I ended up throwing them away and using the adhesive type.
I don't know if the other vendors sell a different design, but I would check those upper snap in clips before you buy if that's what you need.
Good luck.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 03-04-2013, 10:24 AM   #3
50mercfan
50mercfan's Avatar
thanks curt, 72 swb upper and lower
Old 03-07-2013, 09:09 PM   #4
nightmare
nightmare's Avatar
Curt, what was the part number of the trim clips you used? Was it for the individual clips or a set?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 03-08-2013, 12:18 PM   #5
camrycurt
camrycurt's Avatar
I bought them individually because I only wanted to buy the ones I needed.
Here are the part numbers from Classic Parts:
For the good ones that worked:
Upper trim bolt on: 62-882
Lower trim bolt on: 62-876
Lower trim snap in: 62-884
And here's the upper trim snap in clip that didn't work at all for me:
Upper trim snap in: 62-875
If you buy the bolt on clips, you'll need to buy the speed nuts to go with them, part 62-888.
If anyone finds an upper snap in clip that works, I'd sure be interested in hearing about it.
Good luck!
Curt
Old 03-08-2013, 12:46 PM   #6
shawno72
C/10 junkie
shawno72's Avatar
Does anyone know where to get the 67-68 stick on molding clips?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
