Old 03-08-2013, 11:19 PM   #1
rsavage
rsavage's Avatar
Re: Frustrated, discouraged and don't know what to do
Dan,
Sorry to hear of your problem. Couldn't be a cracked flex plate could it? Maybe using a redneck stethoscope (piece of wooden broom handle held up against your ear and against various areas of engine and transmission) could isolate the noise? Hope it is something simple.
Rick
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-09-2013, 12:29 AM   #2
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Originally Posted by rsavage View Post
Dan,
Rick
Hey Rick,
Thanks for your concern. I really checked out the flex plate good to make sure it was fine. I've heard that a cracked flex plate could cause a problem like this. It is a brand new flex plate, but I still checked it out.
BTW... What is this '65 Fairlane?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-09-2013, 01:09 AM   #3
Boog
laying low
Boog's Avatar
So you know the engine isn't torquing over and making the exhaust system bump the frame? You might try backing the timing down a few degrees and run it to eliminate a timing issue. You run a good grade of gas?
I once had an AC fuel pump peck hard like a loose rocker. New one took care of that.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
