Old 02-28-2013, 01:56 PM   #26
dmw319
Re: Manual to Auto (Shift Linkage Problem) help!!
ok awesome! this will be a great help
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 02-28-2013, 02:03 PM   #27
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Yep, been there done that.
Originally Posted by dmw319 View Post
Also, while I got the pro in here, can I remove the clutch pedal even though its attached/mounted to the same piece as the brake pedal?
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 03-08-2013, 11:50 AM   #28
dmw319
Alright yall. I got the old crossmember out so I will try and install the bracket tonight!
Another question: What will I need to do in order for my reverse lights to work? (Moving from manual to automatic steering column)
Old 03-08-2013, 11:58 AM   #29
shawno72
C/10 junkie
shawno72's Avatar
That I did not personally do but its gonna be in the netral safety switch on the column.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-08-2013, 12:53 PM   #30
dmw319
Yea I have the neutral safety switch on the new column, but I have no idea what I should be plugging into it since my harness is for a manual transmission.
Anyone??
Old 03-08-2013, 11:41 PM   #31
WIDESIDE72
WIDESIDE72's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=188684
http://67-72chevytrucks.com/vboard/s...d.php?t=332010
WIDESIDE72 is offline   Reply With Quote
Old 03-09-2013, 01:02 PM   #32
dmw319
Well i got the column in but the indicator seems to be off a bit and the arm on the column isn't very smooth going between gears. Any ideas?
Also the steering wheel is cocked to the left about 45 degrees when I'm driving so it's not straight on. What's the best way to fix these issues?
Thanks!!
Old 03-09-2013, 11:59 PM   #33
dmw319
This answered my question:
http://67-72chevytrucks.com/vboard/s...gear+indicator
Seems like I just have the tab on the bottom of the column (looking from under the hood) too far over!
