3 inch "Z" or 3.5 inch?
Okay, I'm getting ready to "Z" my frame. I have 2.5 dropped spindles, 1.5 pancake xmember with bags. Aired out, I'm about 1/2 inch from laying xmember. It's very hard to hold a tape measure and take a photo but you get the idea in the second photo. As you can see I'm about 3.5 inches from laying frame. I'd just like some opinions whether to go all the way to 3.5 or just go with 3 inches?
Re: 3 inch "Z" or 3.5 inch?
the more you go the more you will have to tunnel your cab....there now alot of room for the trans
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
I have never done one....but i know theres not alot of room...maybe search this site "Z frame..theres some here that do it...if it was me. so not I would go no more then 2 1/2 "
Some people have moved their motors forward an inch and tilt the motor slightly so that the tunnel isn't so affected. Then you have a lot less to modify on the floor.
#6 | |
Also a strange thing, I Z'd 3 inches (vertical) last weekend and she looks great but when I mounted my horns, I set my front clip in for good measure. I tacked the horns in place and they are well over a 3 inch drop maybe 4 or 5 inches lower. When I lay out, the horns lay with the frame evenly. It's got me scratching my head. All my fender to door, hood to fender line up and have straight lines....ever seen this? I'll post photos next weekend. |
#7 | |
I haven't experienced that myself but I think I go about things way different than most. I hang the fenders and place the mounts according to where needed and measure. or vicea versa |
![]() Join Date: Mar 2005
3"/3.5" is a bunch of "Z", and you might have issues in a few areas. If you're planning to use the stock steering box in the stock location, your steering shaft is going to hit the top of the driver's side control arm. The steering linkage might get a little weird, too. The idler arm may not be long enough to secure to the passenger side framerail because it's now 3" to 3.5" higher than normal. If you're not running the high hump cab, you're going to hit on the transmission, and you'll need to build a new tunnel. You're going to need to build another trans crossmember, or space your current crossmember up a whole bunch. You'll have to keep an eye on your driveshaft angle and space up the carrier bearing. I'm not sure, but you might be real close on the brake booster and the heater box if you try to get the valve covers off. You'll also have to get creative on the front sway bar. The stock front sway bar brackets on the frame are too low in relation to the 3"/3.5" height change of the lower control arm attach point, and the sway bar will be at a downward tilt and won't be in it's optimal location.
After a lot of figuring, we decided that a 2" Z gave me the extra crossmember clearance without a whole lot of hassle. I will have to put a very small c-section in the upper control arm for steering shaft clearance. I had to redrill one new hole in my idler arm so it would bolt up. I removed the front sway bar hangers and bolted the mount saddles directly to the frame. I have a high hump cab, and I have plenty of trans clearance. I had to build 2" spacers on my trans crossmember and I also built a shim for the carrier bearing to get the pinion angle back to stock. With a 2" Z, you can still use the stock inner fenders if you trim the bottoms. If you decide to Z the frame, make sure you move the whole assembly forward 1" at the same time to center the wheels in the wheel openings. The farther you lower a 60-66, the more the wheels move back in the wheel openings. A 1" change in the wheelbase makes a huge difference in appearance. Z'ing a chassis gives you a lot of great features for hardly any money at all. In this case, more is not always better. You can send yourself down a rabbit hole where you wind up modifying everything, and it may get to a point where you regret your decision. If your ultimate goal is to lay frame, you might want to consider that the rockers and bedsides hang way lower than the frame. If the body hits the ground first, then laying frame is a moot point.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 03-10-2013 at 03:18 PM. |
#9 | |
I just installed the engine and trans (T5) today. I had to remove the ebrake linkage on the ebrake xmember to slip it in. In the next few weekends I'll be addressing the low hump and trans xmember and front sway bar. I'm sure PB will get a plug on this thread by someone and that's okay but I prefer to build a "glue together" instead of a "snap together" model. I enjoy the build so far even though sometimes it feels like it will never end. It's a journey of meeting people, searching for parts, using engineering and mechanical skills. So far, it keeps me of the streets....literally! ![]()
A spirit with a vision is a dream with a mission - Neil Peart RUSH Last edited by Realnoisy; 03-10-2013 at 06:19 PM. |
#10 | |
I COMPLETELY agree with your last paragraph. Don't get me wrong...I love Nathan Porter's stuff, and if I was building a high-end vehicle, I would use his parts. I've always been a guy who would rather crawl through a wrecking yard or hit the swapmeets to build my vehicles. I love making things work out of parts that most people don't give a second glance. If I see an article on how to build something for $500, my brain starts spinning and I'll figure out how to build something even nicer for $200. It's the way I'm wired. I've tried to keep that same theme during the build-up of my '64, and it has been one of the most fun projects I have ever done.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Are the tires in your pic the ones your gonna run? Maybe a lower profile tire?
Oh now you are gonna' throw that into the mix...lol! I have to admit, I haven't even thought about a lower profile tire. If I did go with a lower profile tire, I will probably lay real hard but it would give me the hood clearance and the option to lay rocker. Hmmm!
A spirit with a vision is a dream with a mission - Neil Peart RUSH |
