Closed Thread
Old 03-05-2013, 08:00 PM   #1776
Speedbumpauto
Speedbumpauto's Avatar
Re: What Did You Do With Your Truck Today ?
Installed a NO LIMIT cowl vent panel replacement without the louvers. It is crazy cool for those of us who aren't going to use the vents anyway. I discovered the product while reading this forum and there was a question about whether wipers would work or not. They work very well all you have to do is locate and drill the holes. Everything else is there. It took a little tuning on the fiberglass around the short side edges to match my body lines and I had to drill the front mounting holes + plus the wiper arm holes. Installed and removed about 6 times to get it properly fit, about 3 hours and it's slick for those of you considering the mod. Now for paint.
Speedbumpauto is offline
Old 03-08-2013, 04:53 AM   #1777
agnes the dog
agnes the dog's Avatar
Put in some Cadillac buckets and ran some new plug wires.... Here's a pic of the buckets before I put the carpet back in.
agnes the dog is offline
Old 03-09-2013, 03:34 PM   #1778
NEWFISHER
NEWFISHER's Avatar
Those look comfy!
I always wanted a P51 Mustang, This is the closest I will get
NEWFISHER is offline
Old 03-09-2013, 10:55 PM   #1779
Daze57
Daze57's Avatar
i hear ya ! i always wanted a B-24 Liberator but i dont think it would fit in the cab of my 57 !!! ahhhhh well ya know !
Daze57 is offline
Old 03-10-2013, 03:02 PM   #1780
OrrieG
OrrieG's Avatar
More wiring....
OrrieG is offline
Old 03-10-2013, 05:02 PM   #1781
agnes the dog
That is too cool! Nice!!!
Old 03-10-2013, 09:43 PM   #1782
Dan in Pasadena
Dan in Pasadena's Avatar
I finally did SOMETHING on my truck today!
Been wanting to use her as a weekend driver and since Daylight Savings Time stated today I figured it was a good day to begin. I'd already pulled the cross panel in front of the radiator & latch assembly. I could see the grill & apron below were very dirty and had lots of surface rust. Pulled the whole front off:
The grill is in good overall condition:
Backside has "light" surface rust considering its never been off there for 58 years!
I'm debating using either naval jelly OR Ospho on this backside. I COULD use my El Cheapo Craftsman siphon sandblaster if I stay back so as not to warp it. Opinions?
Dan in Pasadena is offline
Old 03-10-2013, 10:27 PM   #1783
Dan in Pasadena
Sorry for the double grill photo. Didn't edit it fast enough and now it won't let me.
Old 03-10-2013, 11:12 PM   #1784
NEWFISHER
NEWFISHER's Avatar
Go go go Dan!
Old 03-11-2013, 04:35 PM   #1785
1-ton of fun
polishing a turd
1-ton of fun's Avatar
no pics, but i disassembled the front clip. finally getting back to work on mine after it sat for a few years.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline
Old 03-11-2013, 04:38 PM   #1786
crossfire84
crossfire84's Avatar
my new fuel tank came today.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 03-11-2013, 10:43 PM   #1787
Dan in Pasadena
Go go go Dan!
Ha ha ha, I know what that means: Get OFF YOUR ASS Dan!
So I came down with a case of anal glaucoma today (I couldn't see my ass going to work!) took the day off to do a little more work today. I hit OSH and Home Depot early for Rustoleum Rust Reformer, some naval jelly and some Ospho - or whatever HD calls theirs. Here's how it went....so far!
Backside of front bumper: Crusty rust & old chrome bubbling loose in places:
Following directions I diluted Ospho 3:1 and sprayed one side. Full strength by brush on other side. Kept it wet for HOURS - not much happened. After 8 hours my impatient ass was tired of waiting (Yes Virginia, I know you're supposed to wait 24hrs.) I washed it off, dried & used a 3M wheel to remove the remaining rust and loose flaky chrome. Came out decent:
In the center (above) you can KINDA see where the Ospho pooled so it stayed submerged/worked best. I bet it would work great if you get $100 worth (riiight) to submerge a big part in a kiddie pool.
After, I sprayed it with the Reformer and up close it came out quite smooth given where it started:
Hit it with the Rust Reformer - Don't flame me, I like that stuff. I don't know if it's just black spray paint and I'm fooling myself, but I'm going willingly!
Old 03-11-2013, 10:57 PM   #1788
Dan in Pasadena
Oh and P.S. I also used the 3M wheel to strip the front side of the grill under-apron. I wire brushed the backside (sorry, forgot to take a pic) and sprayed it AND the grill with the Rust Reformer. Label says you've gotta wait 24hrs (grrrr...) to top coat. Pics of THAT hopefully tomorrow.
Stripped but Reformer on the mounts where the 3M wheel couldn't reach. I DID spend a while to scrape the loosest rust off with a flat screwdriver. Best I could do.
BEFORE:
AFTER:
Old 03-11-2013, 11:39 PM   #1789
rootbeer ride
epoxy primed a few pieces and started welding patch panels on the left fender.
rootbeer ride is offline
Old 03-12-2013, 05:30 AM   #1790
dicer
Where do you get the cowl panel with out louvors?
They used to be available in steel.
I need a web address or link, can't find no limit....???
dicer is offline
Old 03-12-2013, 10:10 AM   #1791
Dan in Pasadena
Nolimitengineering.net I believe.
Old 03-12-2013, 02:36 PM   #1792
oldcouple
oldcouple's Avatar
[/quote]
for what it will cost you in time and materials, plus getting it media blasted and painted you can buy a new chrome one. Just be sure to paint the back side with a sealer coat, as it will rust eventually too. http://www.ebay.com/itm/1955-1956-55...f0f9a4&vxp=mtr
Retired and too busy to work.
oldcouple is offline
Old 03-12-2013, 05:20 PM   #1793
Rednek13x
Rednek13x's Avatar
After two years, i finally installed the new clutch in my truck.. Now to work on getting it running.
Rednek13x is offline
Old 03-12-2013, 06:42 PM   #1794
FarmerSid
FarmerSid's Avatar
continued working on one of my rear fenders. Welded a new piece in the flange that bolts to the box side. Been putting in overtime so only have a few hrs here and there to tinker.
FarmerSid is offline
Old 03-12-2013, 09:44 PM   #1795
Dan in Pasadena
oldcouple - I'm pretty sure that's a Chinese grille and I've heard differing opinions on whether they fit properly or not. I WILL have a chrome grille someday but for the present I'm just trying to get my truck to a clean, reliable weekend driver. THEN later I will likely blow it all apart and do high end paint and chrome.
Old 03-13-2013, 06:39 PM   #1796
mknittle
mknittle's Avatar
Those look comfy!
That looks cool.
There is a 57 napco{I think. memory blurs} with a sheet metal bed floor that is painted to look like rivited aluminum panels including nose art.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 03-13-2013, 08:12 PM   #1797
OrrieG
OrrieG's Avatar
Got as far as I could with the under hood/headlight wiring. On to the dash...
OrrieG is offline
Old 03-17-2013, 04:38 PM   #1798
OrrieG
OrrieG's Avatar
Finished headlight and engine wiring except for turnsignals (need to dig out the turnsignal grille). Got all the dash done except for a couple of minor things. On to the back, but need to fab a bumper infill piece first.
OrrieG is offline
Old 03-17-2013, 06:15 PM   #1799
FarmerSid
FarmerSid's Avatar
Finished the rear driver fender mounting flange and started pounding out the small dents here and there.
Old 03-17-2013, 10:17 PM   #1800
Highsider
Highsider's Avatar
Yesterday I took a drive on the back country roads down in Missouri. I had just rolled it out of the shop for the first time since November's snow hit.
The plan was to verify the gas tank's range and enjoy the nice heater on a cloudy cold day.
It ran dry 3-miles from the gas station, which is another 3-miles from home. Now I know.
Highsider is offline
Closed Thread
