Closed Thread
Old 03-11-2013, 09:42 PM   #7151
Hx16457
Hx16457's Avatar
Re: What did you do to your truck today?
Finally finished rear end swap and got to drive her again!
Now I have vibration at 60mph! What tha!!!!!! I ran her after I had the drive shaft shortened and no vibration but now with the rear end swap! Tab-day flippen vibration anyone have any ideas???
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline
Old 03-11-2013, 09:54 PM   #7152
dantimdad
dantimdad's Avatar
Check and see if the u bolts are tight enough. Also, did you change the fluid in the rear end? Finally, remove the wheels completely and put them back on.
I had a car with a wicked vibration. Took off the wheels to inspect a couple things and found nothing until I put the wheels back on and notice a little catch that very slightly kept it from seating all the way. A few licks with a rat tail file in the lug holes and it tightened up really well.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 03-11-2013, 10:04 PM   #7153
Trsmotrhed
Trsmotrhed's Avatar
Steven
Check your pinion angle. I had another truck I put a 9" under and thought I had the same angle as the old 12 bolt. A few shims and was perfect. Just an idea. Frustrating when you make sure everything is perfect and BAM there's a problem. There's some
Forums that explain the vibration and if you need to go up or down. Hope you figure it out and let us know.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 03-11-2013, 10:27 PM   #7154
donthekawguy
donthekawguy's Avatar
I drove around town, stopped at the local hot rod restoration shop and had the body guy take a look at my fenders and bed. My starter has been a little slow lately so I thought today would be a good day to change it. I jacked the truck up and pulled the old one out. Looked kinda weird but off to the parts place. They don't have one to match and I had no idea what year my motor is so I drive home, get the numbers off the block and search. I find out what the motor is and go back to the store. They still don't have a match then I realize it's a high torque starter. Duh! Get the right starter and oil change stuff since the truck is in the air anyway. Find out I don't have the right bolts, back to the parts store, find out I need bigger wire connector thinggies, back to the store. Get everything on, change the oil and fire it up. No smoke, fire or sparks. No oil gushing out life is good. Grab the dog head down to the Jr. High do some doughnuts in the parking lot for the skaters and head home. Who woulda thought it would take 7 hours to change a starter and oil?
66 shorty
donthekawguy is offline
Old 03-11-2013, 10:42 PM   #7155
Hx16457
Hx16457's Avatar
Steven
Good idea I have to pull the tire on the driver side anyway because the brake is adjusted out too far, getting a little hot!
Thanks for the input!
Hx16457 is offline
Old 03-11-2013, 10:45 PM   #7156
Hx16457
Hx16457's Avatar
Okay I guess I can google that "checking pinion angle"?
And what the heck can I shim?
You are 100% correct on it being frustrating! 100%!
Hx16457 is offline
Old 03-11-2013, 10:53 PM   #7157
Trsmotrhed
Trsmotrhed's Avatar
Good luck. Keep us updated on what you find. Helps the next guy out.
63 SWB C10
Old 03-11-2013, 11:01 PM   #7158
Hx16457
Hx16457's Avatar
Steven
Oh yes I changed the oil and rechecked the u bolts too!
Sorry I forgot to answer those 2!
Hx16457 is offline
Old 03-11-2013, 11:03 PM   #7159
Trsmotrhed
Trsmotrhed's Avatar
Brothers, CPP make degree shims to put your yoke back at the right angle. The shims go between your trailing arms and axle pad to angle the rear end up or down. Pinion angle is a big discussion. Basically if the tranny is 3 degrees down the rear end need 3 degrees up from level ground. So if your truck has any rake that adds to the angle but still the same. Even if parked on a slope. Make sense?
63 SWB C10
Old 03-11-2013, 11:11 PM   #7160
jayoldschool
Moderator
Another quick thing to try is flipping the driveshaft 180 degrees from the way you have it mounted.
jayoldschool is offline
Old 03-12-2013, 06:07 AM   #7161
Hx16457
Hx16457's Avatar
Yep makes sense!
Hx16457 is offline
Old 03-12-2013, 06:08 AM   #7162
Hx16457
Hx16457's Avatar
Okay I can do that too! Thx
Hx16457 is offline
Old 03-12-2013, 10:15 AM   #7163
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
If you have or haven"t found information on pinion angle for our trucks specifically, I can tell you that unless the suspension has been highly modified, chances are, pinion angle has not been affected enough to worry about. However. pinion angle, on our trucks, is adjusted by putting a shim between the axle and trailing arm. This is the cheapest and easiest way to do it.
And I see now that I have posted that others have told you that too...
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 03-12-2013, 02:34 PM   #7164
towersddg9
towersddg9's Avatar
Getting close
towersddg9 is offline
Old 03-12-2013, 05:39 PM   #7165
CRGRS 66
CRGRS 66's Avatar
Originally Posted by towersddg9 View Post
Getting close
Looks awesome!!!!! Do you have a build thread? Oh, nevermind, found it.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 03-12-2013, 05:51 PM   #7166
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Did a great 2nd gear rolling burn out .. I am loving the great air here in the state of TX
GMR-PERFORMANCE is offline
Old 03-13-2013, 12:58 AM   #7167
63ChevC10
63ChevC10's Avatar
Finally got around to replacing the water pump today...well actually tonight after work. It's amazing how much quieter it is! The bearing in the old one was shot, but it wasn't leaking out of the weep hole yet. I swear these 6's are bullet proof!
63ChevC10 is offline
Old 03-13-2013, 06:59 PM   #7168
LVPhotos
LVPhotos's Avatar
Paint shop! Extra side piece is for Daytona Blue spray out.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 03-13-2013, 07:12 PM   #7169
Blue_Aura
Blue_Aura's Avatar
That's going to be one NICE 62. Keep up the great work.
Seeing the pics of the body work your are doing makes me a little sick, because last weekend I just bent the rail above the grill (the one in your last pic) and have to try to bend it back out as much as possible without damaging the existing paint.
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline
Old 03-13-2013, 08:24 PM   #7170
mud.man.rj
mud.man.rj's Avatar
I like the back rims too on the 62.
mud.man.rj is offline
Old 03-13-2013, 09:17 PM   #7171
LVPhotos
LVPhotos's Avatar
Waiting for PorterBuilt crossmember install for the fronts 18x8 and 255/40 Nitto 555s.
Parts and powdercoat on list. Money money and more money. Plus just got a Dodge Cummings one ton 4x4. Only if Chevy had solid axle. Work better pickup.
LVPhotos is offline
Old 03-13-2013, 09:19 PM   #7172
rideblue00
rideblue00's Avatar
what did i do? nuthin I gotta get a move on! I always come here for some inspiration!
rideblue00 is offline
Old 03-13-2013, 09:31 PM   #7173
62 Barnfind
62 Barnfind's Avatar
Painted my rear fenders and tailgate today. Getting closer to finishing this thing.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 03-13-2013, 09:32 PM   #7174
hemifalcon
Here's what I did today.. Gonna re-attach these tomorrow and work on getting the door mounted and the rocker panel fitted.. Should be really "fun".. I painted the inner parts of the door opening and the back sides of these parts.. (don't need photos of that though..)
Started with this...
and here's it all solid once again..
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline
Old 03-15-2013, 11:04 PM   #7175
Trsmotrhed
Trsmotrhed's Avatar
Fabricating A Template So I Can Build A Trac Bar Bracket After Installing Lowering Springs. Sorry For The Caps. Phone Updated And Freaking Out.
63 SWB C10
Closed Thread
