Old 03-11-2013, 08:15 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
A speedometer Mystery
O.K. , I spent all weekend making some repairs and updates to my stepper. New heater controls and cables, new dash panel and some minor wiring snafu's. Found the connector for the heater blower switch was half melted and was approaching meltdown. Managed to cobble up a new connector amd got the heater working again, even the light, which I didn't have. My question: Installed a "new" built-up dash with a used speedometer, Camaro (ala Gringloco) tach and all LED lights. The new sppedometer works great and is very smooth, but it appears to be reading faster than the old one. Do some of these speedos use a different "turn ratio"? Old speedo was about 10% slow, which I attributed to the larger diameter rear tires, but the "new" one appears to be reading faster. Same cable, etc., but ~5% fast.
What gives?
TobyArnot is offline   Reply With Quote
Old 03-11-2013, 10:53 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: A speedometer Mystery
Could very well have a different ratio in the head. I don't know if this site will help you at all but there is a lot of information on it.
http://www.transmissioncenter.net/sp...n_______va.htm
LockDoc
Leon
Old 03-12-2013, 09:22 AM   #3
TobyArnot
TobyArnot's Avatar
Thanks Leon,
That's a great site, but it looks like most of the differences are on the tranny end. I didn't change anything but the speedo head itself. The linked page for "speedometer calibration" addresses the "turns per mile" issue and there may well be a difference there. The old speedo was (I assume [?] - original '70 model) had a round high beam light opening and a white on black field. The replacement speedo (year unknown) has a rectangular high beam opening and a pale green on black field. I'm too sore from crawling around under the dash to pull it and look for any small numbers referenced on the calibration page.
To top it all off, this morning as I was leaving the house for work in a light misting rain, the wipers aren't working, but that's another whole issue.
I think I will call the number on the website later today and pick the guy's brain.
Again, thanks for the assistance.
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
Old 03-12-2013, 09:46 AM   #4
cdowns
cdowns's Avatar
sounds to me like you were guessin b4 and guessin now with not a real true fact of what is what or how fast u r really goin
me? i'd drop the truck off at a place that has speedo certification and i'd pay to have it calibrated accuratly
Old 03-12-2013, 10:38 AM   #5
Sammy
Borrow a GPS from someone. It will then give you accurate info on what your truck is saying versus the speedo.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-12-2013, 11:15 AM   #6
71swb4x4
71swb4x4's Avatar
The wipers aren't a whole different issue. The motor is behind the instrument cluster it's possible you inadvertently unplugged it.
As far as I know there aren't different speedo heads. As Cliff says you really need to check it rather thn assume.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-12-2013, 11:31 AM   #7
LockDoc
LockDoc's Avatar
Originally Posted by TobyArnot View Post
Thanks Leon,
wwaah:To top it all off, this morning as I was leaving the house for work in a light misting rain, the wipers aren't working, but that's another whole issue.
Not a problem Toby.
As far as the wipers check this thread out when you start digging into that problem.
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
LockDoc
Leon
