gas tank relocation
I am sure this has been cover a million times, but what is the best way to relocate the tank to under the bed? i know lmc sells a kit but not sire how much fabrication that would take. Or what about using a tank from a same model year suburban or panel? where were the tanks located on those? Or is there and side saddle tanks that would work? any help would be greatly appreciated.
Re: gas tank relocation
Why move the tank under the bed at all? I just spent $$$ retro-fitting my tank back into the cab. The PO had put the tank under the bed.
Issues: The underbed tank hung down too far. The spare tire had to go into the bed. The filler system needed to fill the tank the PO created through the side of the bed was a total rube-goldberg mess. Think about it before you go to all the trouble. FWIW
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
what did you do w/ the tank that came from out under the bed? i could use it,fabricate the filler neck to come out the back.can you help me? 66 chev. swb s.s. 5th wheel side mount. aka:"the beatnick"
Don't want to hijack this thread, but I am going to sell the rear tank, but for local pickup only. I don't want the shipping hassle of shipping a used tank. I will yank it out this weekend. I will list it in "for sale" section when it is out.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB Last edited by bonehead; 02-07-2013 at 11:52 AM. |
After a quick search, I found lots of good reading. Check it out.
Search for Fuel tank relocate http://67-72chevytrucks.com/vboard/s...?searchid=3535 Search for under bed gas tank http://67-72chevytrucks.com/vboard/s...archid=3535242
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
Here are some shot of what I did:
http://kieth.smugmug.com/Trucks/66-G...5592&k=MqQqJfG http://kieth.smugmug.com/Trucks/66-G...0690&k=5cxcPkV http://kieth.smugmug.com/Trucks/66-G...0096&k=WfTFcBh it is a blazer fuel tank, we modified it to take a stock TBI fuel pump, relocated the filler neck to make it a straight shot thru the floor Kieth ![]() |
yea i can understand the shipping rules & regs. but how about the brackets & straps how much for those? and can you provide me w/ the dimensions of the tank lengthX width X depth.
Has any one tried using a side saddle tank from a 73-81 truck? I have a k10 and it looks like the crossmember between the 2 leaf spring shackles would be in the way for installing a tank from lmc, I really just want to get the tank out of the cab to free up space behind the seat
Having weight behind the rear axle helps the handling and weight distribution of our trucks............JMO Kieth
#10 | |
After an accident my significant other had in our '66 GMC and the way the cab was crushed on the drivers' side- I'll never have another in cab tank. It it hadn't been relocated, it would have for sure been crushed and leaked fuel into a cab she couldn't get out of.
My personal opinion is they are alot safer behind the axle. Putting the spare tire in the bed is not that big of hassle to me. Again just my opinion and my preferrence, others have differnt thoughts and that's cool. ![]() It's your truck, build it your way. |
![]() Join Date: Mar 2012
I'd move it out of the cab. Everyone has their opinions that's why we build our own trucks the we you want. The kits at brothers and LMC come with everything you need. Also make sure you get the right ohms for your fuel gauge. Yours is probably the 30 ohms.
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#13 | |
![]() Join Date: Sep 2009
the one to look at is losthopes truck that was in an acident. tank was ripped and he was covered in gas. but luckily no spark. and he is alive and well.
#15 |
Pics of my rear tank. pic from rear 20 ft back 10 inches off ground, can`t see tank, hangs down less than my spare did..
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#16 |
fat old dude
![]() Join Date: Feb 2010
what tank is that rich
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
#17 |
You can get this tank at two locations, mine is from Bob Drake, reason is it has a smaller filler so I could run it thru the frame by mounting the tank lower in the frame thereby keeping the rear bed sill in place, if you move the tank up to clear the frame you can`t keep the rear bed sill, not enough room. I used a filler from a GEO Prism, 1 3/8 size and the filler vent goes all the way to the top to prevent filling issues ( air pockets )
Tanks Inc http://www.tanksinc.com/index.cfm/pa...rod/prd249.htm 16 or 18 gallon, stainless, plain steel, FI setup or standard fuel line, light frame rail clearance needed, crossmember removal and replacement. No drain plug Bob Drake http://www.bobdrake.com/ItemForm.aspx?Item=C4952-9200 Same as Tanks inc other than tank filler and vent tube attached to tank, and filler is 1 3/8 size tube and has drain plug. Everything else is the same ,,, __________________
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Last edited by Rich 5150 69; 03-11-2013 at 04:16 PM. |
#18 |
My 3 cents.... If you're going for all out resto., you have no choice... tank in cab. ANYTHING other than a restoration, get that tank out of cab... Its a dang bomb! there's a reason late model trucks don't have a tank in cab.....side saddle tanks are only slightly less dangerous than an in cab tank... What if you get "T" boned??? The frame needs to protect the fuel tank, just like a roll cage in a race car.....
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
