Re: Frustrated, discouraged and don't know what to do
Is your alternator new? Sounds like Bearings grinding. Or possibly an AC clutch, Could even be the water pump bearings..Did they dyno it with accessories?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
All my front end accessories are new. I have a new alternator, water pump, power steering pump and A/C compressor. They are part of a March system. All are driven off of a single serpentine belt. I eliminated these items as a possible cause by removing the serpentine belt and taking the truck for a quick drive, just long enough to find out it still makes the noise. To answer your question, no it was not dyno'd with the accessories.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Anything new yet?
____________________________ 1967 C10 SWB Big Block 4 Speed |
Hey Austinstocker, it's ironic that you ask. Last night I went out to work on it a bit and decided to brake torque the truck again. I could definitely hear the tapping/knocking noise, but could not tell where it's coming from. Again... I can only get it do it with load on it. It will not do it when sitting idling or revved. This does tell me it's not anything rotational though like drive shaft.
I will continue my quest for an answer.
