Old 02-22-2009, 06:08 PM   #1
Blue666
Tailgates without Chains
I'm putting my bed back together & don't want to use the stock chains & hooks.
What after market or OEM parts have you guys adapted to fit your 64 - 66 fleetsides? I plan to use stainless barrel slides to secure the gate but what type of flat bars or cables work best? Was any cutting of the tailgate required?
Blue666 is offline   Reply With Quote
Old 02-22-2009, 06:50 PM   #2
jason65
Registerd User
jason65's Avatar
Re: Tailgates without Chains
Welcome. Check out my build thread. I got an aftermarket tailgate from mar-k. Hope you get the info you want.
jason65 is offline   Reply With Quote
Old 02-22-2009, 07:28 PM   #3
Blue666
Smile Re: Tailgates without Chains
That's really trick set up but at nearly $600 w/o shipping is beyond my current budget. It does look great though as does the rest of your project. You are doiing some gret work.
MAR K sells the slide barrels & chain eliminators for $150, I was hoping to find an even lower cost option.
ANy ideas or pictures would be great. Thanks
Old 02-22-2009, 08:36 PM   #4
jason65
Registerd User
jason65's Avatar
I've seen people use latches simular to the ones mar-k sells but made for the doors on sheds and such from the ho depo or lowes and I don't see why the linkages from a square body wouldn't work.
Old 02-22-2009, 08:53 PM   #5
502tripower
502tripower's Avatar
This is the hardware from a late model S10. I bought a wrecked tailgate for 5.00.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 02-22-2009, 09:29 PM   #6
Woogeroo
502tripower,
that looks really nice and very well done. I take it that you just pull those tabs of bolts inward to get the latches to release?
-W
some more options to look at:
http://www.wow-products.com/
products / tailgate
http://www.persh.org/pickup/IdeaPage.htm
look under Tailgate & Beds
-W
Woogeroo is offline   Reply With Quote
Old 02-22-2009, 09:36 PM   #7
Blue666
502TriPower, that is the solution I was looking for. That cost is more in my very small ballpark.
Did you weld the MAR-K type slide bolts to the S-10 latch? Does the whole latch unbolt & slide out from the end of the tailgate? Do th cables hide in the space between the tailgate & the bed or do the cables store in the bed?
Thanks,
Blue666
Old 02-23-2009, 12:16 AM   #8
502tripower
Originally Posted by Woogeroo View Post
502tripower,
-W
Yes, The bolts that you see will be replaced with some nice polished stainless bezels and some chrome Pike nuts.
http://www.bitterendchoppers.com/Hardware.html
products / tailgate
-W
Thanks,
Blue666
I did not use any aftermarket products. It is all the S10 hardware fit into my tailgate. The cables tuck up just as they would in the S10 or any of the later tailgate using the cables. If you look at the one pic you will see were the inside of the tailgate was trimmed to accomodate the cables.This pic may show it a bit better...Good Luck with your project...
98' FXD
2002 2500HD
Old 02-23-2009, 12:35 AM   #9
slepysal
slepysal's Avatar
l You want cheep? Like Jason65 said use gate latches I did mine this way
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-23-2009, 11:10 PM   #10
austex66
austex66's Avatar
The previous owner on my stepside used 80' model tailgate hinges and welded seat belt loop to the tailgate and the buckle side to the bed. Really cool. I'll get some pics posted...
and for the curious ones, my display shelf from lowes for $10!
austex66 is offline   Reply With Quote
Old 03-13-2013, 12:43 PM   #11
aspiringthomas
aspiringthomas's Avatar
I am thinking about putting a regular latch on the outside of the tailgate and doing away with the chains. May have an old 73-87 tailgate laying around to get the handle and guts.
aspiringthomas is offline   Reply With Quote
Old 03-13-2013, 04:21 PM   #12
newbe351
I used latches and cables from Frantsen. They have bolt on or weld on. Give them a call, real easy to get along with........
http://www.frantsen.com/chevygmc.html
newbe351 is offline   Reply With Quote
Old 03-13-2013, 06:56 PM   #13
LVPhotos
LVPhotos's Avatar
http://www.mar-k.com/Catalog/catalog.aspx
$75 from Mar-K. Latches up to you. I am taking the hidden one off and going with cam locking clam style.
http://www.horkeyswoodandparts.com/page17.html
They also have hidden latches and supports.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
